nailhead speed parts
Discussion in 'The Hokey Ass Message Board' started by donut29, Aug 2, 2008.
  1. zman
    zman
    from Garner, NC
    If by special you mean a stock one. :rolleyes: The finned ones fit fine with most aftermarket intakes, the stock intakes usually hit. Sometimes you can mill off enough though.
  2. mj40's
    mj40's
    Russell Martin sells these on Ebay and says this is the only aluminum finned valley cover that can be used with the 66 Q-Jet intake!
  3. zman
    zman
    from Garner, NC
    Without modification should be in there... Those should be the Don Kring ones. http://buicknailheadspecialties.com/
  4. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    Sure spacers will cure the problem and milling might make it useable but this engine is in a closed hood car not a yawning show car so its no big deal to use a stock valley cover. I'll take the valley cover to the next swap meet and bring back something else I can use.
  5. donut29
    donut29
    from canton MI
    anything new?
  6. tgd61
    tgd61
    Ok, niiice thread!! Puttin a stock dual quad 401 Nailhead in a Model A...limited radiator space. Z'd channeled etc...If I put the radiator over the crossmember it will only yield me 16 " tall core (plus tanks) What radiators and size etc are you guys using in the early cars with the Nailheads? dont want top run hot!
  7. langy
    langy
    You wouldn't happen to have a link for the ebay cover would you ???
  8. zman
    zman
    from Garner, NC
    call Russ directly 530-272-1564 it'll be cheaper than eBay, no fees.
    http://www.centervilleautorepair.com/
  9. langy
    langy
  10. donut29
    donut29
    from canton MI
    Anyone have anything to add
  11. x77matt
    x77matt
    Here is my 66 425. Factory dual quads and have the air cleaner too. The chrome valve covers are now on ***us's wall I think!
    Have a 364 flywheel setup in the cl***ifieds too...
    Matt
  12. mj40's
    mj40's
    Here are some better shots of my Dual Coil. Not sure I'm going to be able to run it because of firewall clearance. May have to change that. I need one of these driver side headers, anyone? 57-58 from a 364.
    Deuces likes this.
  13. George G
    George G
    So what car is this out of? It's factory? Which engine will it fit. Need to find something for my 401.
  14. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
    401 Nailhead, originally from a 62 Wildcat
    • Weiand Valve Covers
    • Eelco Finned Valley Pan
    • Nicson Front Cover/Mount
    • Chuckles Garage Blower Intake
    • Littlefield Supercharger with 40t and 41t Pulleys Slightly Overdriven, 15psi
    • Runs on 117 Octane VP C-16
    • Cragar Belt Tensioner
    • 2" Pulleys
    • High Flow Valves
    • MSD Distributor
    • MSD 6AL
    • MSD Boost Timing Master
    • Custom Grind Comp Cams "Big Mutha Thumpr"
    • Performance Valve Springs (Unknown Make....Motor Built in late 60's)
    • 10.5:1 Custom Pistons (Unknown Make....Motor Built in late 60's)
    • Custom Rods (Unknown Make....Motor Built in late 60's)
    There is some kind of unknown hocus pocus and witchcraft done to the rocker ***emblies as well.....they have been modified for for better oiling and I ***ume performance too. The crank is stock, but seems to have been toyed with as well. This motor was built for a 60's drag boat and never used......tucked away and forgotten.
  15. titus
    titus
    I dont think ive added anything to my nailhead collection other than a set of NOS hurst motor mounts.
    Im still looking for a weiand drag star high rise 6x2 if anyone knows of one, i have a weiand drag star low rise to trade.
    I have all the 6x2s made for nailhead other than that.
    edelbrock b58
    offenhauser
    gotha lm103
    Did edelbrock make a high rise?
    JEFF
  16. Chuckles Garage
    Chuckles Garage
    Alliance Vendor
  17. Ghost28
    Ghost28
    I picked up this 62 401 with a dynaflow this last saturday. It came out of a 54 ford hot rod truck, and now it's gonna go into a 1926 buick sedan.
    So leave some speed parts for me.:)
    Deuces likes this.
  18. 32coupedeville
    32coupedeville
    from cincy
    here is my 32 coupe i am building out of a 4 door sedan. i just scored a weiand drag star .
    Deuces likes this.
  19. I got one for ya! How about a factory experimental dual quad aluminum intake :D
    Deuces likes this.
  20. I don't have a nailhead engine but 'could look at this stuff for hours:)
    Great stuff.
    More please...:)
    CM
  21. Carb-Otto
    Carb-Otto
    from FINkLAND
  22. zman
    zman
    from Garner, NC
  23. Carb-Otto
    Carb-Otto
    from FINkLAND
    Thank you zman! Item is relisted and link above is correct now.
    Question about another part:
    I bought this nailhead timing cover recently. It is NOS item and came with nice old package also. I've seen better casting work during my life... polished it a bit yesterday and will continue tonight.
    Don't know how rare these are..? If they are not, does someone have similar and possibly knowledge which oil seal I should use on it? This old "shoelace" -type seal has totally dried out. Some part number would be great info or possibly some tip which car uses oil seal of same size? Would not like to use that old style oil seal...
    Deuces likes this.
  24. zman
    zman
    from Garner, NC
    You can use a timing cover seal from a Buick 455. CR#19786 or FederalMogul 474272
  25. Carb-Otto
    Carb-Otto
    from FINkLAND
    ^ Thanks again, zman!
    Anyone have DuCoil distributor for nailhead for sale? I might be interested...
  26. titus
    titus
    added an edmunds 2x2 and 2x4 intake to my collection and a weiand 3x2 401.
    Anyone have pics of a cragar nailhead 471 blower intake?
    JEFF
    Deuces likes this.
  27. 31modelo
    31modelo
    Just picked up a Alchol inj 364 with some really amazing head work. Came with Weiand VC's, MT al rods, full roller cam, 15:1 pistons, hydro w/ adapter really a cool engine. Built in 58
      110.6 KB
      114.6 KB
    Deuces likes this.
  28. donut29
    donut29
    from canton MI
    Need more pic plz:D
  29. slacker1965
    slacker1965
    saw that one on daytona cl......neat parts....
  30. 29tudor
    29tudor
    Bump. Slid the body back n dropped in the mag. Buildin some knarly zoomies and straight carb linkage
