Nailhead tech/Q&A links...
Discussion in 'The Hokey Ass Message Board' started by Fat Hack, Jul 14, 2006.
  1. Fat Hack
    Fat Hack
    from Detroit
    Ok, there's always lots of interest in Nailheads around here, and since I was reading up on some of what's been covered in the past, I thought I'd throw together a list of links to threads on the HAMB dealing with various Nailhead questions and stuff.
    Some of the questions come up several times, and some info is repeated, but this makes finding the answer to your question...or just doing a little research that much easier!
    I'm sure I missed some, but here's a few to get you fellow Nailhead junkies started!
    Feel free to add any that I overlooked, to make this an easy springboard for other HAMBers looking for Nailhead info and answers to common questions!
    Dig in!
    :) :cool:
    322 Nailhead transmissions:
    http://www.jalopyjournal.com/forum/showthread.php?t=120083&highlight=nailhead
    425 carb replacement:
    http://www.jalopyjournal.com/forum/showthread.php?t=118733&highlight=nailhead
    401 Nailhead cooling:
    http://www.jalopyjournal.com/forum/showthread.php?t=119755&highlight=nailhead
    Nailhead into a 40 Ford:
    http://www.jalopyjournal.com/forum/showthread.php?t=119913&highlight=nailhead
    Nailhead generator mounting:
    http://www.jalopyjournal.com/forum/showthread.php?t=119157&highlight=nailhead
    Nailhead pic request:
    http://www.jalopyjournal.com/forum/showthread.php?t=118943&highlight=nailhead
    401 Nailhead into 63 LeSabre:
    http://www.jalopyjournal.com/forum/showthread.php?t=117991&highlight=nailhead
    Road draft tube and coolant crossover questions:
    http://www.jalopyjournal.com/forum/showthread.php?t=118279&highlight=nailhead
    Six carb 364 question:
    http://www.jalopyjournal.com/forum/showthread.php?t=117566&highlight=nailhead
    Nailhead (401) valve spring source:
    http://www.jalopyjournal.com/forum/showthread.php?t=117720&highlight=nailhead
    Nailhead (322) spark plug recommendations:
    http://www.jalopyjournal.com/forum/showthread.php?t=117703&highlight=nailhead
    Nailhead cam recommendations:
    http://www.jalopyjournal.com/forum/showthread.php?t=19944&highlight=nailhead
    Weiand timing cover re-pops:
    http://www.jalopyjournal.com/forum/showthread.php?t=116141&highlight=nailhead
    Nailhead rebuild info in print:
    http://www.jalopyjournal.com/forum/showthread.php?t=114306&highlight=nailhead
    Switch-Pitch converter question:
    http://www.jalopyjournal.com/forum/showthread.php?t=114811&highlight=nailhead
    364 intake question:
    http://www.jalopyjournal.com/forum/showthread.php?t=114418&highlight=nailhead
    1956 Nailhead ID question:
    http://www.jalopyjournal.com/forum/showthread.php?t=114336&highlight=nailhead
    B.O.P. to Nailhead compatability question:
    http://www.jalopyjournal.com/forum/showthread.php?t=114266&highlight=nailhead
    322 to early Ford toploader clutch linkage question:
    http://www.jalopyjournal.com/forum/showthread.php?t=113871&highlight=nailhead
    322 to four speed question:
    http://www.jalopyjournal.com/forum/showthread.php?t=113615&highlight=nailhead
    322 in Model A radiator question:
    http://www.jalopyjournal.com/forum/showthread.php?t=112504&highlight=nailhead
    401 Nailhead questions:
    http://www.jalopyjournal.com/forum/showthread.php?t=112356&highlight=nailhead
    322 pressure plate question:
    http://www.jalopyjournal.com/forum/showthread.php?t=112171&highlight=nailhead
    Nailhead multi-carb installation tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=111590&highlight=nailhead
    322 starter/flywheel mods:
    http://www.jalopyjournal.com/forum/showthread.php?t=112083&highlight=nailhead
    Weiand 3x2 intake question:
    http://www.jalopyjournal.com/forum/showthread.php?t=111364&highlight=nailhead
    Eelco/NW Speed bellhousing question:
    http://www.jalopyjournal.com/forum/showthread.php?t=110354&highlight=nailhead
    Nailhead multi-carb intakes question:
    http://www.jalopyjournal.com/forum/showthread.php?t=110476&highlight=nailhead
    Source for 322 header flanges:
    http://www.jalopyjournal.com/forum/showthread.php?t=98129&highlight=nailhead
    Nailhead carb questions:
    http://www.jalopyjournal.com/forum/showthread.php?t=108948&highlight=nailhead
    Nailhead exhaust manifold interchangeability question:
    http://www.jalopyjournal.com/forum/showthread.php?t=107904&highlight=nailhead
    Nailhead parts & services directory listings:
    http://www.jalopyjournal.com/forum/showthread.php?t=96479&highlight=nailhead
    401 to four speed question:
    http://www.jalopyjournal.com/forum/showthread.php?t=107058&highlight=nailhead
    Nailhead pricing question:
    http://www.jalopyjournal.com/forum/showthread.php?t=106507&highlight=nailhead
    Dynaflow question:
    http://www.jalopyjournal.com/forum/showthread.php?t=105147&highlight=nailhead
    Nailhead speed parts link:
    http://www.jalopyjournal.com/forum/showthread.php?t=104397&highlight=nailhead
    Nailhead ID questions:
    http://www.jalopyjournal.com/forum/showthread.php?t=104313&highlight=nailhead
    Lakeheaders.com U-fab intakes question:
    http://www.jalopyjournal.com/forum/showthread.php?t=103966&highlight=nailhead
    322 mini starter question:
    http://www.jalopyjournal.com/forum/showthread.php?t=103777&highlight=nailhead
    Another Nailhead in a Model A radiator question:
    http://www.jalopyjournal.com/forum/showthread.php?t=102119&highlight=nailhead
    1966 Electra engine question:
    http://www.jalopyjournal.com/forum/showthread.php?t=102132&highlight=nailhead
    Nailhead trans adapter questions:
    http://www.jalopyjournal.com/forum/showthread.php?t=101793&highlight=nailhead
    322 transmission adapter questions:
    http://www.jalopyjournal.com/forum/showthread.php?t=99432&highlight=nailhead
    Nailhead casting number question:
    http://www.jalopyjournal.com/forum/showthread.php?t=99231&highlight=nailhead
    322 ID question:
    http://www.jalopyjournal.com/forum/showthread.php?t=98670&highlight=nailhead
    Question about Dyanaflow replacement options:
    http://www.jalopyjournal.com/forum/showthread.php?t=98077&highlight=nailhead
    http://www.jalopyjournal.com/forum/showthread.php?t=98076&highlight=nailhead
    Nailhead to Ford C4 auto ****** question:
    http://www.jalopyjournal.com/forum/showthread.php?t=97034&highlight=nailhead
    Nailhead lifter valley question:
    http://www.jalopyjournal.com/forum/showthread.php?t=97346&highlight=nailhead
    264 vacuum line question:
    http://www.jalopyjournal.com/forum/showthread.php?t=96488&highlight=nailhead
    1956 Buick Nailhead driveline compatability question:
    http://www.jalopyjournal.com/forum/showthread.php?t=95996&highlight=nailhead
    Nailhead tripple 97 tuning/trobleshooting help request:
    http://www.jalopyjournal.com/forum/showthread.php?t=95489&highlight=nailhead
    425 cracked block question:
    http://www.jalopyjournal.com/forum/showthread.php?t=94116&highlight=nailhead
    Nailhead to 700r4 question:
    http://www.jalopyjournal.com/forum/showthread.php?t=93841&highlight=nailhead
    Blown early Nailhead link:
    http://www.jalopyjournal.com/forum/showthread.php?t=93667&highlight=nailhead
    1957-61 364 block question:
    http://www.jalopyjournal.com/forum/showthread.php?t=93709&highlight=nailhead
  2. LeadSledMerc
    LeadSledMerc
    Thanks Fat Hack, there are some real good threads in here I know I missed.
    LSM
  3. Toystoretom
    Toystoretom
    Sweeeet!!! I have a 55 Special with a 264 and the boat anchor Dynaflow and I just love it, the most relaxing ride in the world. Every time I take her out I come back grinning from ear to ear :D. Have you ever tried to pick up a Dynaflow? If you were to drop it, it would knock the Earth out of orbit...
    I found a 55 Super sitting in a field that had a 322 in it and was able to buy the whole car for very little. It had sat there for years, and the tires were sunk down in the dirt. The car itself was on a moderate slope, and the E Brake didn't work, and I thought it might be a good idea if I could get the regular brakes to pump up before we pulled that tank out of there. I pulled up the floor mat and began to unscrew the cast iron cap to the master cylinder, and my buddy, who was helping me, got right over my left shoulder and about knocked me into the car. Feeling a little uncomfortable that he was so close and behind me (I didn't know he was that way) I turned around to get him to back off and it wasn't my buddy, it was a very large cow who wanted to see what I was doing to her car :eek:. I just kinda crawled into the car and went out the p***enger door, that thing outweighed me just a little, and I'm a lover... not a fighter anyways... Turns out the cow liked me, it followed me around all afternoon, I coulda took it home too...
    We pulled the car out and I took it back to the shop and gave the 322 a gas I.V., did just a little work to the ignition, hotwired the starter and actually got that baby to fire up, after it had sat in that field for a VERY long time. It smoked a little (I think everyone smoked in the 50's, didn't they?) so I'll probably rebuild it and maybe put it in the Special... I pulled as many parts as I could and had the rest of the car hauled off for s****.. there wasn't much left.
    All these links are great... thanks for sharing :)
  4. Big Dan
    Big Dan
    Fat Hack..............That my good man is an awesome gathering of NAILHEAD stuff that every NAILHEADER needs to know (did I create a new word)...? DAN
  5. Fat Hack
    Fat Hack
    from Detroit
    Ha Ha...I suppose so...kinda like NAILHEADOPHILE!!!!:D
  6. Mudslinger
    Mudslinger
    Sorry for the O/T but what would a decent nailhead 4v with trans from a running car be worth? I have a friend that has one stored away.
    It doesnt run now but he pulled it from a car he was driving and has it stored.
  7. Fat Hack
    Fat Hack
    from Detroit
    What year and size Nailhead?
    What transmission?
    What kind of Buick is it out of?
    The above info would help folks give you a more accurate estimate.
  8. steevil
    steevil
  9. Fat Hack
    Fat Hack
    from Detroit
  10. Mudslinger
    Mudslinger
    IM not really sure its something like 64-65 Wildcat? Its an automatic. He sin another state so I cant get the info right now IM going from memory.
  11. Fat Hack
    Fat Hack
    from Detroit
    Here's some more non-HAMB links to help the Nailheadophiles a****st our ranks out:
    (More to come soon!)
    Buicks.Net Nailhead casting numbers:
    http://www.buicks.net/shop/reference/nailhead_casting_numbers.html
    Car Craft's history of the Nailhead:
    http://www.carcraft.com/thehistoryof/65502/
    Nailhead.Org:
    http://www.nailhead.org/poll_archive.php?id=40
    BuickStreet:
    http://www.buickstreet.com/forum/viewforum.php?f=62&sid=47c81bbfe55bd835e7b098258cfb9c4d
    Buicks.Net:
    http://www.autoelf.com/link_in.php?link=292
    V8 Buick's Nailhead forum:
    http://www.v8buick.com/forumdisplay.php?f=9
    Buick Parts Directory:
    http://www.buickpartsdirectory.com/engine.htm
    Vintage Speed's camshafts for 264/322 Nailheads:
    http://www.vintagespeed.com/cams.htm
    TA Performance 364-401-425 camshafts:
    http://www.taperformance.com/nailhead_and_v6_cams.htm
    Speedway Motors 401-425 pistons:
    http://www.speedwaymotors.com/xq/aspx/dept_id.408/display_id.4591/qx/Product.htm
  12. TRAVEZ
    TRAVEZ
    great resource man i appreciate it!
  13. ChevyGirlRox
    ChevyGirlRox
    from Ohio
    awesome list. mucho appreciated!
  14. atch
    atch
    i don't know how i missed this when it first came out, but here's a bttt for anyone else who missed it.
    thanx hack!
  15. Duration
    Duration
    from Wayne, MI
    i will be reading these links for ages. thanks brother!
  16. thurstin
    thurstin
    thanks alot for the links :D
  17. belair
    belair
    thanks for doing this.
  18. Wicked50
    Wicked50
    These are GREAT!!!!
  19. 35mastr
    35mastr
    from Norcal
    Also my good freind Russ Martin is a real good source for buick parts. He is also a real good wealth of info.
    www.nailheadbuick.com
  20. hotrod1940
    hotrod1940
    Thanks for taking the vast amount of time it took to ***emble this list.
  21. welded78
    welded78
    from ct
    thanks i can see a couple sleepless nights of reading coming awsome colection of info thanks again
  22. AntiBling
    AntiBling
    Thanks for this!
