Nailhead trans ?
Discussion in 'The Hokey Ass Message Board' started by onelow48, Feb 20, 2004.
  1. onelow48
    onelow48
    from Maryland
    I have a 401 in a 63 Buick. I would like to to put a R-4
    in place of the Dyna/slow. I know people have done this in
    Inpalas. Does anyone know if the bolt paterns are the same?
    Or if any late model Buicks had R-4's?
  2. BLAKE
    BLAKE
    From Buickperformance.com - "Looking to install a 700R4 behind a nailhead 401/425, contact: Rod N Racin, 715 East Main St, Belleville, IL 62220, 618-257-0567. Price for the adapter kit is $295."
    Also, try Bendtsen's.
  3. onelow48
    onelow48
    from Maryland
    Thanx for the info!
  4. kustombuilder
    kustombuilder
    from Novi, MI
    you need an adapter but they do make em. do a search for transmision adapters....
  5. nailhead_sled
    nailhead_sled
    Do you really need a 700r4? Do you already have one lying around?
    I would consider an alternative (which doesn’t require an expensive adaptor)
    For lucky ‘late model’ Nailhead owners like yourself you have the option of running the Switch Pitch TH400. The s/p has two stall speeds: 1800 and 2800 rpm
    It was available from 65-66.
    For the whole skinny on the s/p check out Switch Pitch Trans for Older Nailheads
