Nailhead Tri-Y headers for the 32
Discussion in 'The Hokey Ass Message Board' started by Clark, Apr 10, 2005.
  1. Clark
    Clark
    Suedesled...this is the early motor with the round ports. I wish you had the early style. I've got more time in the flanges than I do in the actual headers.
    To make the flanges I used a 2 1/2" wide and 3/8" thick steel. Measured several times and drilled the port holes first. Then clamped the flanges to a set of manifolds with the ports lined up and drilled the bolt holes. Then I used the plaz to get rid of some of the bulk and give them a nice look. The port holes were drilled with an 1 1/2" hole saw. Worked great with the 1 1/2" U bends.
    Clark
    PS...I guess it would be nice if I posted some finished pics
  2. joeycarpunk
    joeycarpunk
    from MN,USA
    Nice looking job as usual.
  3. Judd
    Judd
    Clark
    They look great! Somebody needs to make flanges for the 264/322 heads.
  4. Paul
    Paul
    Editor
    ahhh mannn... "so it's not really a hot rod then"
    you've traded performance for appearance,
    and them that know tri-Y won't know Y...:rolleyes:
    Paul
  5. suedesled
    suedesled
    Oh yeah, I remember that now. I have the early ones in the works now.
  6. Big Dad
    Big Dad
    Old thread but ..
    who does WHITE header coating .. Jet Hots site does not list the color
    Anyone got a link, or # ?
  7. Big Dad
    Big Dad
  8. Clark,
    Did you use a TIG?
    Was it hard to weld the relatively thin tubing to the thick(er) flanges?
    Any lessons learned that you'd care to pass on to others?
    Thanks,
    Gary
  9. Clark
    Clark
    Big Dad..we lost our white header coat guy. We're looking pretty hard for a new one right now. Unfortunately the best way I've been told to do it is have them coated silver scuff and paint with high heat paint....actually isn't a bad idea if you think about it.
    Gary..Mig. I've done several sets and no problems. I did learn to tack them to the flanges on the underside then copletely weld them on the inside.
    Clark
