Technical Nailhead water crossover
Discussion in 'The Hokey Ass Message Board' started by desotot, Jan 9, 2021.
  1. desotot
    desotot
    I want to reinstall my water crossover on my 65 425 nailhead but I dont have the rubber seal that goes on the bottom and my O ring kit doesn't have any thing close to the size I need. Can I use a 3/8 " long piece of 3/4 " heater hose? Or maybe someone out there has come up with a better solution. I really don't want to buy a complete engine rebuild gasket set to get that one piece. Thanks Jack
  2. desotot
    desotot
  3. brading
    brading
    Try your local Hydraulic hose supplier they normally have a range of "O" sizes.
    desotot likes this.
  4. Dan Timberlake
    Dan Timberlake
  5. desotot
    desotot
    Yes Dan, thats the one, guess I will try a few more places, maybe like brading suggests a hydraulic place.
  6. hidez57
    hidez57
    try russ @www.centervilleauto.com
    Hamtown Al and desotot like this.
  7. Ort
    Ort
    I am in Santa Cruz CA and have a Hydraulic repair bis. You can order any size and quanity from this company :TRI-C Machine in Sacramento, CA===916-371-8090 ask for Mel. Most likely your area has a similar place.
  8. desotot
    desotot
    Thanks hidze57. Russ has been very helpful with tech info but isn't interested in shipping to Canada.
  9. desotot
    desotot
    Tanks Ort, I will check at the local tractor dealership and see if they have one.
  10. Flat Roy
    Flat Roy
    Easy way , buy the size and type of O-ring material you need on Amazon, cut to proper length, superglue together and wala you got it.
  11. swifty
    swifty
    Russ Martin at Centerville Auto is your Nailhead expert and parts supplier for these engines and he will have what you need. Have you got a mate in the US that it can be shipped to then he can on- ship it to you.
    I bought a heap of Nailhead gaskets from Rock Auto when they were having an old stock clear-out and it included separate gasket sets for valley cover, intake, exhaust, rocker cover, sump, water pump and I ordered 4 thermostat housing gaskets. When they turned up it was 4 off 3" square pieces of jointing material!
    All the gaskets were Felpro brand and if you check on their site they will probably have what you need,
  12. egads
    egads
    It's spelled " Voila ";);)
  13. iafraser39
    iafraser39
    from Warmland
    Get the set from Russ Martin. The knock offs for the ports and the ****** area
    don't seal correctly as the gaskets are too thin.
