Technical name of the steel part inside bushing
Discussion in 'The Hokey Ass Message Board' started by daveheld, Mar 10, 2016.
  1. daveheld
    daveheld
    This might be a dumb question... but what is the piece of steel - round in the center, machined flat on either end that p***es through the poly bushing on the control arm below. I would refer to it as a machined inner bushing sleeve / mount... but that is tough to search. The image is from a corvette c5 - if that matters - just looking for the name of the part so I can describe it to others. I'm spent a few days making these for a new suspension design and would like to see if anyone out there is making them. I have flexibility in my design to use something 'off the shelf' if it exists... thank you
    dave
  2. deathrowdave
    deathrowdave
    from NKy
    Steel , no idea
  3. Atwater Mike
    Atwater Mike
    On this site, it's an 'O.T. IFS' part. :rolleyes: Nice work, though...
  4. Dangerous Dan
    Dangerous Dan
    The man asked a question!!!
  5. captaintaytay
    captaintaytay
    Believe or not it's called a T-Bar. I believe you can even by them as a kit now a days.
    Back in the day it was called a T-Mount type shock. couldn't buy the T part separate at that time.
    We used to use a big press to remove them from worn out shocks to use for some custom designs.
    Maybe someone else has some input also.
  6. gatz
    gatz
    Kept thinking "trunnion"....but that doesn't quite seem to fit, or maybe it does, IDK
    Short of calling it a "control arm bushing mount"
    maybe look for a site that shows the 'Vette parts diagram to find out what GM called it.
  7. blowby
    blowby
    from Nicasio Ca
    The elusive Johnson rod?
  8. Grumbler
    Grumbler
    I'd call it a fitting, but that's just an opinion
  9. 32v
    32v
    from v.i.
    its called a shaft or cross shaft you can buy from aFe power
  10. captaintaytay
    captaintaytay
    T bar kit, QA1 sells them.
    Hnstray likes this.
  11. King ford
    King ford
    from 08302
  12. daveheld
    daveheld
    thank you... i've done some searches on T bar, cross shaft and a couple variants and it looks like QA1 keeps coming up - along with some off road stuff.
    Point of clarification - the initial image was taken from the 'net - it's a C5 mount. I did not make that part. My design is for a crown vic front upper control arm. This part will complete prototype #3 and ready to go into production of a narrowed crown vic crossmember for 1948-52 for trucks. Others to follow. Thanks again for your collective help in identifying the T bar / cross shaft.
    dave
    Cocoa Beach FL
  13. aaggie
    aaggie
    Pivot shaft?
  14. Trunnion = "T bar"
