Name that tool
Discussion in 'The Hokey Ass Message Board' started by cadlights, Sep 13, 2003.
  1. stealthcruiser
    stealthcruiser
    for lubing kingpin bushings,as in when the zerk fittings are frozen and packed with crud.
  2. TagMan
    TagMan
    [ QUOTE ]
    [/ QUOTE ]
    Great guess.....but not correct!! [​IMG]
  3. a/fxcomet
    a/fxcomet
    from Eugene, OR
    For some sort of u-joint?
  4. TagMan
    TagMan
    [ QUOTE ]
    [/ QUOTE ]
    No, but thanks for tryin' !!
  5. TagMan
    TagMan
    No more guesses??? [​IMG] [​IMG] [​IMG]
    The Master Deluxe late 30's Chevys had thin metal encased rear springs. This tool was used to grease the springs. There were two small holes (about 5/64"), each one half-way between the rear axle and the spring shackle, on the bottom of the spring casing. The tip of the tool (pic #2) was screwed into the hole and the tool tightened down to hold the tool to the spring. A grease gun was used on the zerk fitting to fill the casing full of grease. (sample inside view #3)
    pic#2:
    pic#3
  6. Sounds like (leaf) spring bushings to me:)
    I've got '53 Chevy P/U front leafs on the rear of my '34 panel, that's what made me think of spring bushings.
    Dennis
  7. NIPPLE CLAMP!! [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]IIIIIIII LIKE IT!!
  8. cadlights
    cadlights
    from Hooper, Ut
  9. Gr8ballsofir
    Gr8ballsofir
    OK, here's my submission.
  10. Fastsporty
    Fastsporty
    bushing reamer for harley rocker arms. I need one of those.
  11. Gr8ballsofir
    Gr8ballsofir
    You're right and you're wrong...
  12. Fastsporty
    Fastsporty
    ok so that might not be a reamer for harley rocker arms. but I still need one and it looks just like it. so the Q? is what is that reamer for? anyone else.
  13. cadlights
    cadlights
    from Hooper, Ut
    Reamer for kingpin bushings.
  14. Smokin Joe
    Smokin Joe
    Looks like something a cop walking a beat in the "Tenderloin" area of Frisco would carry. [​IMG]
    Gotta be something with a ball to ride in that worm screw on the left. We ain't seeing the whole setup. All I can think of is kingpins, piston rods or steering.
  15. HardLuck
    HardLuck
    Some type of broach?
    ...or a lightsaber?
  16. Meester P
    Meester P
    ajustable reamer.
  17. Gr8ballsofir
    Gr8ballsofir
    Cadlights got it. It's a parallel reamer for late 50's Mopar kingpin bushings. That's not a worm screw Smokin Joe, it's a spring. You can adjust the diameter.
    It was given to me by an old Desoto mechanic!
  18. manyolcars
    manyolcars
    I got this at the swap meet cuz it looks like a hand held English Wheel. What can you tell me about it?
  19. Smokin Joe
    Smokin Joe
    That "spring" had me. I did guess kingpins tho. [​IMG]
  20. Roothawg
    Roothawg
    I'd show ya my tool but then you would think I was starting some kinda magazine.......you old timers know what I'm talking about. [​IMG]
  21. Gr8ballsofir
    Gr8ballsofir
    Just keep your "tool" in your "toolbox"! :rolleyes:
  22. cadlights
    cadlights
    from Hooper, Ut
    The swap meet tool of Manyolcars looks like a tool to set hot patches on inner tubes. What's an inner tube?
    Oh! I'm showing my age. [​IMG]
  23. manyolcars
    manyolcars
    CT Fuzz is showing a valve lapping tool. Now someone tell me about the tool I posted.
  24. cadlights
    cadlights
    from Hooper, Ut
    bttt, we still have a tool to name. HERE!!!!!
  25. BigJim394
    BigJim394
    manyolcars: I have seen tools like that (but a little bigger) advertised on ebay as being 1920's auto body shop "fender straighteners". I don't know if they were correct in their description, but if they were, it really is a kind of hand held english wheel.
  26. SimonSez
    SimonSez
    I second what BigJim said.
    I saw a cool setup at a swap meet that was in the original wooden case with different wheels and instructions. It was different to that, but the same principle.
    I guess there would be nothing to stop you mounting it in a vice and using it the same way as a regular English wheel for small patch panels.
  27. BigJim394
    BigJim394
    manyolcars: If there is a patent number on that tool post it and I'll see if I can find the patent application for it that would tell what it was.
  28. BigJim394
    BigJim394
