Name That Tool
Discussion in 'The Hokey Ass Message Board' started by 4-banger, May 7, 2008.
  1. 4-banger
    4-banger
    from Tucson
    I found this the other day. Wondering what it is?
  2. 56savoy
    56savoy
    from socal
    Looks like a tie rod/ball joint separator to me.
  3. dana barlow
    dana barlow
    from Miami Fla.
    Valve spring compresser /flathead
  4. 4-banger
    4-banger
    from Tucson
    It doesn't compress. The fingers open apart rather than close.
  5. toddc
    toddc
    looks like a valve spring compressor
    They push against the block, hence the opening action
  6. I think a gynacoligist could tell you better! But for now I agree with barlow>>>>.
  7. Ok I'll show you mine just because you showed us yours. I've had this thing laying around for about ten years. Got it with some antique wrenches in a box at an auction. As yours does too this one spreads and doesn't compress. We've asked a hundred people what the heck it is and nobody knows>>>>.
  8. CadDaddy42
    CadDaddy42
    4-Banger
    A good pic end-on of the fingers would help clarify, but it looks like screwing the screw one way will open the fingers apart, and the other way it will compress. And it really looks like a pre-war valve spring compressor. If the cups on the fingers point inward, it is most definitely a valve spring compressor.
    Engine Pro - Yours should only be forced apart by turning the screw, not be forced close by turning the other way. The cups on the fingers point outward, and the size and heavy duty construction would suggest a ball joint separator.
  9. beernut
    beernut
    from solvang
    exhaust manifold spreader?,(used to spread the pipes apart to line up the bolts)
  10. 4-banger
    4-banger
    from Tucson
    The cups do point inward, but the outside parts have grooves for traction on them. Also the design of it looks as if it can apply more force spreading apart (opposite the cups of the fingers). I did try to use it as a valve spring compressor and compressing the spring it broke the small rivet that keeps the fingers on the bar attached to the threads. So I am not sure it was meant for that.
  11. Ratty55
    Ratty55
    from Frohna,MO
    The crossbar has rivets on the outside of the arms. Screw it down and that's going to pull the bar and compress the two arms together. Looks like a valve spring compressor to me
  12. 49ratfink
    49ratfink
    " get on the table and put your feet in the sturrups.. this is going to feel a little cold"...
  13. 38plymouth
    38plymouth
    Brake shoe spreader?
  14. Hey CadDaddy. Mine doesn't have any cups, the fingers are flat on the ends. It,s got some casting #s on it from way back that we have never been able to match to anything. Maybe a it is a joint spreader>>>>.
  15. PoopStain06
    PoopStain06
    from SoCal
    it's for removing the heads off your sisters barbie dolls.
    ok ok,... I have no frickin' idea
  16. beetlejuice55
    beetlejuice55
    i think it's a fancy set of ice tongs.
  17. Mr48chev
    The first one is a style of valve spring compressor for inline flatheads. The second one looks to be a valve spring compressor too but works to push the spring up to compress it. one side would go on the lifter while the other pushed up on the spring retainer.it may be application specific too.
    The second one would work the same way as the tool in fig 3-37 page 77 in this link I looked for a photo and found a whole book . http://books.google.com/books?id=QL...nCpyaNo&sig=moeRnbJYORj2VT8bjnBIHsag_L0&hl=en
  18. ol gasser
    ol gasser
    from here
    The first one is a style of valve spring compressor for inline flatheads. The second one looks to be a valve spring compressor too but works to push the spring up to compress it. one side would go on the lifter while the other pushed up on the spring retainer.it may be application . rIGHT YOU ARE SIR my Dad bought one new way back when and i was with him when he bought it,also saw him use it quite a few times.
  19. I saw the subject line and instantly thought "Paul Webster"......
  20. Muffler belt caliper.
  21. Von Rigg Fink
    Von Rigg Fink
    from Garage
    your quick!..I was just going to type that too..Paul is a Tool
  22. wbrw32
    wbrw32
    Take it from an old man..it is a valve spring compressor!!!!!!
  23. chaos10meter
    chaos10meter
    from PA.
    Meat ball holders
  24. I knew it had something to do with MEAT but I wasn't thinking balls>>>>.
