Name this tacho.
Discussion in 'The Hokey Ass Message Board' started by oppy35, Apr 30, 2011.
  1. Hi all, I have a tacho that I wish to use on my car first question is.. What is it off? And second how can I get it to work with a flathead mechanicaly not electronic? (I want to keep it fairly old school)
    (there should be a pic attached below)
  2. stuart in mn
    stuart in mn
    Since it only goes to 4,000 rpm it probably came off a diesel truck. I'm not sure I understand what you mean about running it mechanically and not electronically...the tach is either mechanical or electronic, you can't use one for the other's purpose. Does it have a mechanical drive on the back, like a speedometer, or does it have screw terminals for wires?
  3. Thanks for the quick reply, it is mecanical and I would rather keep it that way rather then installing a mech to electronic converter. Is there a drive or something of the like that I can use or adapt?
    Why is the readout in reverse? Would it be used along side another tacho for another motor to make reading the two easier??
  4. Dave Downs
    Dave Downs
    from S.E. Penna
    I looks like it is sitting above two aircraft guages, but most aircraft tach's don't read that high -
  5. patrick66
    patrick66
    That's an aircraft tach.
  6. Yeah that are aircraft guages, some others I've been messing around with I'm think about running them aswell.
