Hot Rods Narrow Flathead Rad
Discussion in 'The Hokey Ass Message Board' started by 612DOR, Mar 14, 2017.
  1. 612DOR
    612DOR
    Need some advice. I am putting a 51 Flattie in a 36 frame and want to cover it with a 33 Truck grill. Grill is 19" wide. I can fudge the rest. Anything sorta stock that will fit? I have several rads but they are all too wide. Stock motor except for dual carbs, no AC.
  2. sawbuck
    sawbuck
    from 06492 ct
  3. RICK R 44
    RICK R 44
    The local farm tractor wrecker is a great source for narrow rads. You will have to change the inlets and outlets for the flatty. Do it yourself or have the local rad shop do the balterations
  4. adam401
    adam401
    When I put a 32 comercial grill on my model a in front of a 21 stud flathead I used a 36 car radiator. Grill shell fit beautiful and if I remember correctly I think it even bolted on near the neck without even drilling a single hole. Just a thought. Those radiators have an indent on the underside of the upper tank to accomodate the fan.
  5. adam401
    adam401
    That's a 36 radiator with a commercial grill over it. That's also a model a with a bad head gasket haha
  6. 612DOR
    612DOR
    You mean like one from an 8N?
  7. RICK R 44
    RICK R 44
    Most farm tractors have relatively narrow rads. I would look for one off a tractor of at least 40 H P . The 8N is only about 20 H P and may not have a large enough capacity to cool your flatty. The one I used was narrow enough to fit in a 28/29 model A rad shell. I believe it came off about a 50 H P Ford. I just tool my rad shell to the wreckers and started looking through his supply of rads.
  8. 612DOR
    612DOR
    Ok, thanks for the tip. I also have a recored rad from a sbc that is good size wise, just need to report it. Would this be ample? It's a 3 core.
  9. 612DOR
    612DOR
    No, it's 4 core!
