narrow pattern 64 toploader 4 speed behind y block truck bellhousing
Discussion in 'The Hokey Ass Message Board' started by dirtbag13, Aug 23, 2011.
  1. dirtbag13
    dirtbag13
    been cleaning up and going through some parts i had laying around lately and came across the old 4 speed 64 toploader a friend gave me ! w no bellhousing i never figured i'd do anything with it anyways since they came behind early 5 bolt small block fords ! i noticed it looks to share the same bolt pattern as a y block truck bellhousing i have , will this work behind a y block w the truck bellhousing ?
  2. 390Merc
    390Merc
    from Indiana
    I would think it might fit, never tried that myself.
    I'm guessing by narrow pattern you mean it only has one set of mounting holes? These also were available in Galaxies in 64 as they phased out the T-10. It will have a fairly long tail shaft if so (as compared to a Mustang toploader). The Fairlane for 64 also has this ****** if equipped with a 4-spd. Hard to tell it from a Galaxie but the Fairlane trans is about and 1" or so shorter, as is the main shaft as well. It also has a wide-ratio 1st gear so it is much easier to take off from a stop. I have a 64 Fairlane toploader in a 64 Galaxie, and a later dual bolt pattern toploader in another 64 Galaxie.
    A few other differences between the F'laine & Galaxie toploaders but not worth mentioning at this point.
  3. Skrayp
    Skrayp
    If its a 3 speed bellhousing its too deep. I don't know Y blocks but thats how it is with FE's and a toplaoder should be the same regardless of year. The later ones have both bolt patterns.
  4. stillrunners
    stillrunners
    from dallas
    wtf - no pics?...let me take a guess....yes....it will fit....
  5. dirtbag13
    dirtbag13
    yep just one set of mounting holes !
  6. dirtbag13
    dirtbag13
    uh ya no pics ! swaps been done before was hoping if someone knew if the input shaft would need lengthened or shortened on this particular trans
