Technical Narrowing a Banjo Axle?
Discussion in 'Traditional Hot Rods' started by Mattbee, Sep 29, 2013.
  1. Mattbee
    Mattbee
    I know I can't be the only who has had to have banjo axle shafts narrowed. I have already narrowed the housing but I can't figure out how/who would narrow the shaft. I called moser and they said they can cut and respline the axles, but banjo axles shafts arn't splined, the spider gear is part of the axle and the other end is tappered and they don't have a fixture to narrow it. The other problem I have is that I have another carrier (no axle shafts) that has the spider gear sepreat from the axle with the inside splined so that it can take a splined axle. Is there is a axle that I can use with the other carrier/spider gear and still use a early ford hub and backing plate? This can't be the first time this has been done.
  2. Nobey
    Nobey
    See this post, it might help.
    http://www.jalopyjournal.com/forum/showthread.php?t=624437
  3. Mattbee
    Mattbee
    Bump
  4. ronnieroadster
    ronnieroadster
    A good machine shop that has a lath with a taper attachment would be able to shorten those stock tooth pick axles. You need to find a shop that has an older lath like a Southbend with taper attachment its an easy job on a lath.
  5. Pat
    Pat
    from Felton Ca.
    This is going on memory, But I remember an article using merc axles. Same spider gears but splined. 49 and up axles.
  6. seb fontana
    seb fontana
    from ct
    Yes but you have to use the Merc bearings, brakes..Won't have the early Ford look..
  7. Shaggy
    Shaggy
    from Sultan, WA
    Just take the axle to a good old style machine shop, it'd be a pretty simple job to turn the taper further back, rethread, and cut a keyway no welding required
    If my lathe wasn't****s up, id offer to do it myself
  8. seb fontana
    seb fontana
    from ct
    Most narrowed Banjo rears back in the day I doubt had the axles shortened properly, most were cut and arc welded with added collar over the welded area...If they broke another was made just as easy..With modern weld materials it maybe feasible but the best would be the machining way..I can do them but I am in CT..How hard are you going to beat on them?
  9. change out the axles and housing ends for 9 in pieces
    tk
  10. That,s probably how lot's of doodlebug rear axles were done.
  11. Ken Smith
    Ken Smith
    Alliance Vendor
    We narrow the stock early Ford axles.
    Give us a call. 208-455-7971.
  12. Mr48chev
    That sounds like the best plan. No explaining to the local machine shop worker about how you need it done either. Just give the exact measurements that you shortened each tube and put the axles in a box and take the box down to the brown truck.
    Turn around will probably be faster than waiting for the local job shop machine shop to get to it too.
