Technical Narrowing a Ford 9" rear end
Discussion in 'Traditional Hot Rods' started by thompsonwayne1, Aug 22, 2015.
  1. thompsonwayne1
    thompsonwayne1
    I have a Ford 9" complete rear rear end I picked up to put in my roadster, but would like to narrow it a little bit, just an inch or so on each side. Can I use the stock axles? I know I can cut some off the spline end if necessary, but the question is how much "cheating room" is there on the splines? Are the splines longer than necessary?
    Thanks
  2. McGurk
    McGurk
    from Mid West
    Look at the splines on the axle and they will tell you what you need to know.
    turboroadster and 1927graham like this.
  3. roseville carl
    roseville carl
    You can use the shorter axle from another rear and you will be 2 1/2 " shorter just cut 2 1/2 from long side......
    turboroadster likes this.
  4. mgtstumpy
    mgtstumpy
    Tapered axles can't be shortened, others can provided they don't step down. 28 or 31 spline?
  5. big duece
    big duece
    from kansas
    If you only cut off 1" you will be in an area of the axle that will not be big enough for new spline. You would have to cut off a fair amount to reuse the same spline count. OR, If your pumpkin has 28 splines, you could find some 31 spines axles and have them cut to 28 at what ever length you need.
  6. BOBCRMAN
    BOBCRMAN
    from Holly
    Depending on the budget, time. Ford produced many widths of 9" axles. A short and a long one in most all examples. You can find another axle and shorten one side of the housing as previously stated.
    I built a jig back in the eighties and have shortened/built more than several rears.
    I have used these axles with no problems. Shorten housing on one side and cut one of these axles. Lots of spline on these. My g***er project has two of these type axles, in bigger spline.
    http://www.ebay.com/itm/9-Ford-28-S...yle-/221643046281?vxp=mtr&hash=item339af47d89
    His rear end ruler is a great tool.
  7. I had a Galaxie axles shortened to suit a 56 1/2 diff, done by swapping the short axle to being the long. Then just one axle needs to be shortened.
    This went into a cutdown F100 housing
  8. woodiewagon46
    woodiewagon46
    from New York
    Your question is a little vague. When you say "cheating room", are you saying you just want to narrow your existing axles and not re- splining them and only using the shortened splines? If so don't do it. Narrow the rear and get the proper axles!
  9. You can "cheat" but only by 1/2 inch each side, most axles have at least a extra 1/2" that don't engage the spider gears. A lot of work shortening a housing a 1/2 inch each side to get around getting a axle resplined.
    I'm a cheap ***, best and cheapest option is (IMP) swapping the long for short and only only getting one axle resplined.
  10. One thing about shortening diffs and axles, just try and keep the "pumpkin" in the centre.
    Nothing looks more wrong especially in a spring over than a diff centre housing (pumpkin) sitting offset looking from the back.
    The spring in a perfect arch over the diff but with a off centre housing just looks wrong (In my opinion after a few drinks of good Scotch)
  11. thompsonwayne1
    thompsonwayne1
    Thanks for all the info fellas
