Technical Narrowing Ford 9"
Discussion in 'The Hokey Ass Message Board' started by mokomon, Feb 2, 2021.
  1. mokomon
    mokomon
    Trying to narrow my 1st 9" rearend. The questions I have are,
    1. is the pinion centerline to differential centerline (center point between inner axle ends) measurement 2.125"
    2. is the space between the two axle ends 1.125"
    3. when narrowing the housing ,should I cut off just the bearing end to weld back on or leave some axle tube still attached to it so the weld is maybe say 6" from the bearing end
    31hotrodguy likes this.
  2. Budget36
    Budget36
    I’ll give you a push to the top for the morning crowd.
  3. fiftyv8
    fiftyv8
    from CO & WA
    Check out a couple of youtube video's as they can be inspiring. I've watched a few on this topic and feel empowered to take on such a project in the future..
    Hnstray likes this.
  4. A ch***is shop I used to deal with/hang around would cut the ends off, chuck them in a lathe and remove what remained of the original tube and weld. Ended up with a lip on the housing end that fit the tube perfectly. New housing ends are available as well.
    They never (or at least not that I ever saw) shortened a 9" in the middle of the tube.
    bchctybob, Hnstray and guthriesmith like this.
  5. On E bay you can buy a tool thats a flat piece of steel with all the math marked on it.Place it on the carrier opening,and it references center lines/offsets. You can also buy bearing ends that either **** up,or fit in the tube.
    bchctybob likes this.
  6. Jmountainjr
    Jmountainjr
    To do it correctly you should have a dog bone tool and an alignment bar. You want bearing ends that **** to the tube. But you can do it without the tools and take it to someone for straighten.
    cktasto, swade41 and Just Gary like this.
  7. kabinenroller
    kabinenroller
    The quoted post is the correct method of narrowing a rear end housing. An arbor should be used for correct alignment.
    Have you ever watched one of the “Bozo Motors” television shows that hack a housing off in the middle of the tubes and then stick weld it back together? I cannot believe they actually are able to insert the axle shafts into one of their creations.
    cktasto likes this.
  8. 51504bat
    51504bat
    I know @gimpyshotrods narrows them. Maybe he'll post some thoughts.
  9. typo41
    typo41
    I wish someone would post a nice photo how to,,,,
    So we know how Not Too
  10. jimmy six
    jimmy six
    Cutting the tube is an ez way for an 8.8... not a 9”.
  11. dreracecar
    dreracecar
    from so-cal
    An explanation here,
    was narrowing an Olds dragster housing, the fixture was to scribe the tube cut.
    the cut has to be perfectly square (no gaps) to the bearing end otherwise the weld will pull and the ends no longer square. Looking at the right side, I start the weld at 5 o-clock and weld clockwise, when I weld the left side I start at 7 o-clock and weld counter clockwise.
    Its just the way I do things
  12. Hnstray
    Hnstray
    from Quincy, IL
    So, you only narrow axles in the evening......spacing your welds by two hours?
    Resting and letting the prior weld cool? :D
    Ray
  13. DDDenny
    There is not a one size fits all kind of answer, mostly because of the varied housing tube sizes (and shapes), not to mention the desired final length of the particular project.
    The one "truth" though is the need to use a centering/alignment fixture as well as a way to straighten the housing after welding because even under the best processes some housing designs require more attention than others.
    Here is a Google search with many images and explainanations on housing narrowing, keep in mind that not all of the Youtube how-to's use ideal processes.
    https://www.google.com/search?q=9+i...nYA0oQ_AUoAnoECAQQAg&biw=1280&bih=800&dpr=1.5
    cktasto and Hnstray like this.
  14. nobby
    nobby
    1. it depends on the thickness of the crown wheel and the girth of the pinion, where the diff centre 3/4'' thick bar lands - so when setting up, be mindful as if you start with a set of 3.00 and then go to 4.11 it will change
    2. yes, the diff centre bar is 3/4 and you 'normally' see 1/8 of clearance to the axle shaft
    3. note stock nothing is **** welded, a truck case at the middle - the tube there sits into the centre, on a car case,
    you cant see it with the diff in, but the centre steps down and the tube sits over it, IF doing it here, cut through 1'' after the weld and nibble the remnant away - and mark the old position with a right good punch
    at the bearing housing end, they all sit into the tube
    note however IF you plan on doing this, the tube on some of them - before it is welded to the centre is machined a smidge to receive the bearing housing, or even when you remove all the old tube from the bearing end, it won't go back in, you cannot remove more as the seal is beneath, its rather difficult to open the tube end to receive it when the centre case is welded to it.
  15. I will do***ent mine soon Tony.
  16. mokomon
    mokomon
    Thanks for the replies, I have the alignment bar and bushings for it. My 9" housing has 3.25" housing tubes that narrow to 3" just before the bearing ends. I wasnt sure where to cut the bearing end off in the 3.25" dia and then reweld that to the shortened 3.25" or cut it at the 3" and reweld to the shortened 3.25. I should have stated that in in post.
  17. Marty Strode
    Marty Strode
  18. Mr48chev
    All I am going to say is that some of those "as you see them do it on TV ways are flat wrong by what I have been taught for the past 50 something years.
    The Billet ends that Marty showed cost less than a minimum charge for machine shop time in most shops.
    There is a shop about 15 miles from me that narrows rear ends for the local racers and 4x4 brigade that I have been wanting to check out. If that doesn't work there is this guy on the Hamb who lives about 3-1/2 hours away from me if I don't stop at Cousins in the Dalles for Breakfast who is said to be pretty good at it. I'm sure not going to attempt to do it myself.
  19. TCATTC
    TCATTC
    Desoto291Hemi and Budget36 like this.
  20. ekimneirbo
    ekimneirbo
    Cut one end off at a time so you can use the opposite end as a reference to make it parallel. If you bolt a plate to the solid end, it gives you something extending further out. Make two plates, one for each end. Bolt them in place . Then measure in front from plate to plate and in back plate to plate. Tack the one end and double check the measurements.
    Randall and lake_harley like this.
  21. dreracecar
    dreracecar
    from so-cal
    Had to go home for dinner that day
    milwscruffy, bchctybob and Hnstray like this.
  22. Any thoughts or recommendations on material/diameter to use if building an alignment bar?
  23. Ken Smith
    Ken Smith
    Alliance Vendor
    I wouldn't ***ume either end is square from the factory. I prefer donuts and a bar.
    1.5" diameter Cold Finished Steel
    Hnstray, bchctybob, verno30 and 2 others like this.
  24. Marty Strode
    Marty Strode
    How many bars are there in Caldwell, and do they all serve donuts ?
  25. Ken Smith
    Ken Smith
    Alliance Vendor
    I meant donuts and a maple bar. They can be served together.
  26. Budget36
    Budget36
    Issue is doing it this way, there’s no way to ensure both end centers are on the same place as each other, respective to the carrier bearings and axle centerline.
    If you think about it, say the current housing has a “wow” in it, or an “s”. If you were to make the ends parallel to each other, things are not right right. So now you straighten the housing, and nothing is parallel anymore.
    I think the alignment bar and pucks is the best way to go, but then think about cost of them, how often you’ll be doing it, v just having it done.
  27. Marty Strode
    Marty Strode
    You can use a bar and mandrels as other have stated, but as soon as you weld axle pads, or any suspension brackets to the housing, there is a good chance it will be warped. I always check and straighten every housing after welding.
  28. Would it make sense to weld spring mount pads and any other suspension mounts before the flange ends? The bar and mandrels would then take any warpage in the housing into account.
  29. mgtstumpy
    mgtstumpy
  30. ekimneirbo
    ekimneirbo
    Not everyone is going to have a bar/tube and concentric donuts to align their rear end ends, and even if they do, that does nothing for getting the faces at the ends of the tube parallel with each other. If someone makes two plates with a hole in middle so they can slip over anything.......and drilled with the same pattern as the housing end.......when they bolt them in place, simple measurement between the plates will tell you if they currently parallel with each other OR they are not parallel. If they ARE parallel, then cut one end and weld it back so it's parallel to the uncut end. Being careful to make good straight cuts should be obvious.
    Now if you measure between the plates and they AREN'T parallel.......at least you now know that you have a problem.
    Is this the BEST method?.........NO, but it's better than TLAR that a lot of people use.:D
