Technical Narrowing Rear End Question
Discussion in 'The Hokey Ass Message Board' started by thegearhead, Jan 23, 2019.
  1. Hnstray
    Hnstray
    from Quincy, IL
    Yes, I will concede that design does work ‘well enough’......I changed out a set of axles and bearings on an elderly friend’s older Lincoln Town Car (8.8” axle) a few years ago but it had at least a 100k as I recall. Conventional self contained bearings would have been about as much labor, but less money for parts and less s**** metal.
    31Vicky with a hemi likes this.
  2. Desmodromic
    Desmodromic
    As I mentioned earlier, Sprite/Midget (42" track) and Triumph TR3 (45") are the only stock rear ends that you have a chance of finding in your local s**** yard, which can take maybe 3 and 5 times (respectively) the Crosley's torque. Another possibility for a rear you can easily narrow at home is from an old Jeep, which I think are Dana 44s. The differential is substantially offset, and the axle housings are pressed and welded to the diff case. The long side components can be replaced with a second set of short side pieces. I haven't measured these, but I'm guessing you could reduce the already narrow track by almost a foot. These rears commonly had two piece axles (separate hub attached to a tapered/keyed axle). I'm pretty sure later version had single piece, flanged axles.
    To go off on a tangent:
    Not only does the W196 engine have desmodromic valve gear, but is fabricated from sheet steel, like an early post-war Crosley.
    I see that the roundcase you p***ed up goes for around $150,000, in concours shape.
    I believe Crosley made a few motorcycles. Several home-made specials have been built.
    Hnstray likes this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    My wife was thinking the very same thing.
  4. sdluck
    sdluck
    I believe some forklift had 9 inch ford rear ends.
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Golf Cart's
  6. gimpyshotrods
    gimpyshotrods
    Older Taylor Dunn electric trucks have 9-inch rear ends, 5-on4-1/2" bolt pattern, and all.
    They are chain-drive, to an over-axle motor, that bolts on to the pinion support bolts.
  7. They used the keys hub on Jeeps until they built the J series in '63 or 4 on the trucks. They were still using Keys hubs after that on the CJ.
    You won't find any of the mentioned Brit cars in any s**** yard around here. Way better off to just narrow a rear and be done with it.
  8. Speedway Motors sells axles with extra long splines you can measure and cut to fit.
  9. thegearhead
    thegearhead
    Not to bring back an old thread but more less a update and end to this. Got the vega rear shortened and stock axles resplined at Moser it was no problem has plenty of meat left on old axles to spline and cut c-clip into them. It's sitting in car and awaiting pinon angle adj and brake job.
    Hnstray, saltflats and irishsteve like this.
  10. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I missed this originally. Glad to see you sorted it out. Now if only it was a Quickchange:p
    Hnstray likes this.
