Projects Narrowing trunk lid torsion bars
Discussion in 'The Hokey Ass Message Board' started by kabinenroller, Oct 29, 2017.
  1. kabinenroller
    kabinenroller
    After installing mini tubs in the back of my project car to clear larger tires I had to relocate the trunk hinges about 2 1/2” inboard. Now I need to reinstall the torsion bars that hold the trunk lid open. They are about 3/8”in diameter spring steel with bends on each end. Has anyone had experience in bending spring steel? I am sure heat it not the answer because it would take the spring out of the metal.
    They look like this...
    Thanks!
    Jim
  2. Hnstray
    Hnstray
    from Quincy, IL
    They were either bent cold or hot. do some google research on spring steel....gotta be info out there.
    Ray
  3. squirrel
    I cut an old broom stick to length when I did my altered wheelbase thing. And put a handle on the trunk lid, so I could open it easily.
    You have a fun task ahead of you! let us know if you get them to work again. If you do, I'll be impressed.
    XxMikexX likes this.
  4. You are going to increase the tension by shortening them.Might be too much .
    Not an engineer. Jim would know.
    Maybe use gas shocks instead ?
  5. kabinenroller
    kabinenroller
    Thanks for the ideas. I really prefer not to use a gas strut or a prop rod. The mounts allow multiple positions for the bar so the tension is somewhat adjustable. My fear is that the bars originally were bent then heat treated to make them spring, which would make it more difficult to narrow. I have given some thought to bending them hot then having them heat treated again.
    Jim
    turboroadster likes this.
  6. john worden
    john worden
    from iowa
    Cut, remove required inches and reweld. Metal finish weld.
  7. '51 Norm
    '51 Norm
    from colorado
    Bend 'em and see what happens. If it don't work you are no worse off than you are now.
  8. I'd figure a way to leave the hinges alone.
    But there's this option too
    saltflats and razoo lew like this.
  9. RidgeRunner
    RidgeRunner
    from Western MA
  10. DDDenny
    Works for me!
    saltflats likes this.
  11. gene-koning
    gene-koning
    Whatever you do, cutting and welding them won't work. Spring steel will break right on the side of the weld, welding makes spring steel brittle.
    Mark them where you need to bend them, cold bend them (heat will make the spring steel soft, then it will need to be re-heat treated) around something making tight radius bends, it won't be easy. Then cut off the excess with a cutoff wheel. Gene
    scrap metal 48 and biggeorge like this.
  12. You could shorten and sleeve them, I suppose. I'd notch the sleeve and weld each one ,4 places. Either it holds or it won't. I've welded a lot of **** that shouldn't be done that way, by the books.
    I don't think there's going to be enough material left to work one end with a torch.
    Try it. Worst that can is it falls on your head while you're fueling it , and the car burns to the ground. Those gas shocks would look pretty good then.
  13. Lowtek32
    Lowtek32
    Can you find some from a donor car and experiment? I once used them for radiator support rods. Cut and threaded they were very strong and worked ok, but I worried I would get speared if I crashed -i took them off!
  14. 57Custom300
    57Custom300
    from Arizona
    Timely post. The tailgate on my 60 Ford is missing one torsion bar and finding one has been impossible. I was thinking of going with a gas strut but wondered if they would work. I see now it's been done.
  15. BJR
    BJR
    I had a very big (think 1900's) old, over stuffed rocking chair years ago that the spring under it broke. It was about 3/8" in diameter. I sleeved it and welded it and it held for the next 10 years and then I sold it. From that experience I would shorten it in the center, sleeve it and weld it.
  16. DDDenny
    They work so good that I go out and open my Novas trunk lid just to see how good it works.
    There are a few kits available for some cars but for the most part its just trial and error.
    Took a couple trips to NAPA but luckily the strut market has a lot of length options.
    57Custom300 likes this.
  17. squirrel
    if you want a wider variety of gas springs, McMaster Carr (and probably others) sell them in all different sizes, spring rates, end fittings, etc. so you don't have to be limited to what was used on cars.
  18. I've got a question about this project.
    Every tub job I've every done, I'd cut the hinges loose from the original tub, shorten the brackets, then re-mount in the same relative place. If you move the hinges in, you would have to modify the deck lid too, yes?
    117harv likes this.
  19. That's what I was thinking
  20. 19Fordy
    19Fordy
    There must be a way to fabricate the new wheel well so that you can still attach the stock trunk torsion rods.
    Keep thinking.
  21. Stonebird
    Stonebird
    I cut mine and rebent the ends when I narrowed the trunk for my roadster project. Don't mremember if I used any heat or not. I think I just did it cold. They are stiffer now but I had a couple of different slots to mount the spring. I used the lower slot. You could also bend them with a little less pre load built in. Mine has been opened and shut many times without any problems.
    rjones35 likes this.
  22. ss823
    ss823
    like Mark Yac said. I was pretty green when I did mine 30 yrs ago. made an adapter from the stock bracket to the new wheelwell & it works as it did before. SS
  23. SS327
    SS327
    What about going to the junk yard and finding shorter length ones from a different car like a 82-85 Skylark or something small like that?
    Denny
  24. kabinenroller
    kabinenroller
    First off I would like to thank everyone for your suggestions and cautions in solving this problem.
    I believe I have the solution. During one of our groups lunch “meetings” I brought up the trunk torsion bar issue. I mentioned some of the comments I received here on the HAMB and also said that I wanted to figure out how to make the stock bars work. One of my friends who is a very experienced hot rod builder and a retired tool maker said “why don’t you cut the bars to the needed width then sleeve and pin them?” My immediate response was yes why not?
    So I took the bars mounted them on the table of the Bridgeport and milled a flat on a section about 8”long. I then turned up two sleeves And drilled them to match the OD of the rod. I inserted each end 1 1/2” into the sleeve and counter drilled into the milled face slightly. When the pointed end on the set screw is tighted it goes into the counter drilled spot to make the sleeve secure. I was carefull to make sure the rods were indexed so that the ends lined up just as they did before I sectioned them.
    I installed them in the car and the trunk lid goes up and stays there just like it should. I see no reason why this should not continue to work, the set screws are very tight in the rods.
    Here are a couple of pictures that will hopefully explain what I did. (The picture of the sleeve is deceiving, it looks like the set screws are are not in line)
    Maybe this will help one of you on your project.
    Jim
    51569390-4709-4653-A3AE-4A34F15FBA5F.jpeg 9451A139-856D-48CD-884A-513EAB046472.jpeg
    pat59 and 31Vicky with a hemi like this.
  25. squirrel
  26. very nice jim. another great idea from the saturday lunch crowd. I need to stop by and check out all of the progress.
  27. gdaddy
    gdaddy
    from nw fl.
    very nice , simple and effective
  28. willys36
    willys36
    Go ahead and bend them in your press. Suspension sway bars are the same steel and I reshape them all the time. Did this one for the rear end on my '36 Pontiac. Ford Courier bars are great feed stock for street rod sway bars. I bent this one in about 4" per side.
