Narrowing Wheels? Is this Safe?
Discussion in 'The Hokey Ass Message Board' started by deto, Apr 19, 2012.
  1. deto
    deto
    So I found a wheel with the correct offset for my application, but the problem is that it is 1" too wide and contacts my tie rod end. I have access to a lathe large enough to mount a 15" wheel. If I were to section the rim, by removing an inch from the center then welding the 2 halves back together, would this be a safe wheel to drive on? I plan on welding the wheel while mounted to the lathe head so I can constantly check run out. Any body think this is a death wish?
  2. HotRod31
    HotRod31
    I don't see a problem if you can keep it straight and more important if you can weld :)
    Later, Mark
  3. F&J
    F&J
    ^ X2, there won't be a problem if you follow that advice. I've done it on a brake lathe, first time was 30 years ago; chromed steelies that I took an inch out of the backspace.
    ...and i am still alive :)
  4. 117harv
    117harv
    Unless you have access to the lathe and welder for free and can do it yourself, you might be better off buying a new one that suits your requirements. It is a steel wheel right? There is no problem doing what you want, it's been done thousands of times before.
  5. metal man
    metal man
    Well,I sure hope it's safe, cause I've done it a whole bunch of times.
  6. deto
    deto
    ok. Yeah I have access to everything I need for free, and yeah I can weld. Now here is another question: I would like to TIG them. Would I be better off Mig welding them or is this ok?
  7. 117harv
    117harv
    Wire or tig, i prefer tig though. It sounds like you have what you need and know what you are doing, get busy, take pics, and post them:)
  8. Marty Strode
    Marty Strode
    I bought a pair of wheels that had been parted off, when putting them back together I tig welded them inside and out, they were for a circle track application, so I didn't bother to grind the weld down on the outside.
  9. Unkl Ian
    Unkl Ian
    Your wheel modification, will be as good as your welding is.
    For my car, I would not hesitate.
  10. gimpyshotrods
    gimpyshotrods
    You betcha'. My head hurts just thinking about it.:eek:
  11. Shaggy
    Shaggy
    from Sultan, WA
    Only if your welding is safe....
  12. hotflint
    hotflint
    I have cut many rims on a lathe, steel and aluminum, I use a rubber belt taped on with packing tape, the wheel also distorts from the resonating. I use one 2 inches by about 3/8. This facilitates in aiding the problem of it howling and it distorting. Tig welding introduced less heat and will distort less as well as being a better, purer weld.
  13. deto
    deto
    I love all the info guys. I can always count on the HAMB for good advice. Thanks!
  14. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I'd let Marty weld my wheels!
    Since I just got my own tig welder, I wouldn't attempt it until I get more experience. But watch out when I get comfortable with this, everything will be tiged!!!! (is that the past tense of tig)
  15. What about heating and bending the steering arms in an inch on both sides, I've done that several times, just a thought.
  16. Heo2
    Heo2
    One warning you can destroy the bearings in the
    lathe if you weld the rim in the late welding current
    p*** trough the bearings and due to the bad contact
    burn the bearings.
    My father told me so but since i was younger and
    wiser than him. I continued welding in the lathe
    since i grounded in the rim there was no way that
    would happen.After 2 years of widening and narrowing
    rims.I had the pleasure of change bearings while hearing
    what did i tell you
  17. deto
    deto
    AH YES! the arc between them will give me nice little flat spots in my bearings. Ok, I wont be doing that. I might just put them on the hub and do it that way. Thanks for the input.
  18. Heo2
    Heo2
    draw a line over the rim so you got it back
    in same place after you removed the inch
    and it will fit real nice together and you
    will have no problem with runout
    and a regular steelrim is no way near
    perfect unaltered
    I prefer tiging my rims take longer but
    quieter less sparks and splatter
    more beautyful to fore the tire to look on
  19. deto
    deto
    already grabbed my scribe... We're on the same page
  20. Heo2
    Heo2
    well then hit it and good luck
  21. Mr48chev
    That would be the same as wrapping the rubber vibration dampening strap around a brake drum. It will also make for a lot smoother cut.
    You might want to check your state's RCW's though as I believe this state has something in it about welded rims not being acceptable. It states no cracks or repairs by welding on the rim. That you can read what you want into.
    section 2.
    <table style="padding-right:5px" border="0" cellpadding="0" cellspacing="0" width="100%"><tbody><tr><td valign="bottom">RCW 46.37.369
    Wheels and front suspension.
    </td> <td nowrap="nowrap" valign="top" align="right">
    </td> </tr> </tbody></table> (1) No vehicle shall be equipped with wheel nuts, hub caps, or wheel discs extending outside the body of the vehicle when viewed from directly above which:
    (a) Incorporate winged projections; or
    (b) Cons***ute a hazard to pedestrians and cyclists.
    For the purposes of this section, a wheel nut is defined as an exposed nut which is mounted at the center or hub of a wheel, and is not one of the ordinary hexagonal nuts which secure a wheel to an axle and are normally covered by a hub cap or wheel disc.
    (2) Tire rims and wheel discs shall have no visible cracks, elongated bolt holes, or indications of repair by welding. In addition, the lateral and radial runout of each rim bead area shall not exceed one-eighth of an inch of total indicated runout.
    (3) King pins or ball joints shall not be worn to the extent that front wheels tip in or out more than one-quarter of an inch at the lower edge of the tire.
  22. gimpyshotrods
    gimpyshotrods
    Metal-finish your welds, and they won't be visible.
  23. deto
    deto
    ok so... I spoke before I checked. The lathe isn't big enough. The rim hits the ways when it's chucked up. Anybody local to me wanna let me use their brake lathe?
  24. deto
    deto
    Actually hold that thought. I moonlight a couple nights a week at another shop. I will check on monday and see if it's possible for me to use that one.
  25. jimbousman
    jimbousman
    Done it a few times. Only problem I had was getting the rim air tight so I could run tubeless tires. Took a few touchup welds to get it right.
  26. docmike
    docmike
    Officer: It looks like you been weldin' on these here rims? Accordin' to section 2. RCW 46.37.369,Tire rims and wheel discs shall have no visible cracks, elongated bolt holes, or indications of repair by welding.
    Driver of car: What weld? Oh, this weld? I don't know anything about that, it goes all the way around the wheel. It looks like that's how the wheel was manufactured.
    Doc
  27. buick320a
    buick320a
    from indiana
    Hell.........we have done it with no lathe.........cut it with torch, grind smoth, set it back togeather and but two squares across the faces to true them up.........
  28. Country Gent
    Country Gent
    Skidmarks has the right proceedure as far as welding. I have narrowed and widened over a 1000 wheels and have never had a problem. You got to know how to weld as mentioned by others. In the beginning and even on occasion now ,I stick weld em with 6013 on high amps with a 3/32 rod. Good penatration and flat bead. Always welded them on the inside. You wind up with a nice outside appearance if your welding is on the money.practice, practice!! But now you got **** in your game as your lathe is too small, but will the other shop be willing to possibly screw up their bearings.MMMMMM
  29. Xdrag48
    Xdrag48
  30. A Boner
    A Boner
    The way I read it, it says you can't repair it by welding......it says nothing about welding it to narrow it!
