Narrowing Wheels? Is this Safe?
Discussion in 'The Hokey Ass Message Board' started by deto, Apr 19, 2012.
  1. gimpyshotrods
    gimpyshotrods
    "...indications of repair by welding."
    Leave no trace.
  2. Hackerbilt
    Hackerbilt
    I expect that they mean repairing elongated or damaged bolt holes etc...not that a wheel CANNOT be built using welding.
    They just want to keep unsafe parts from being reused.
  3. desotot
    desotot
    I hav a friend who widens and narrows rims using an old wheel balancer.
  4. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    On old steel wheels the centers are either welded in or riveted in, I dont see how welding on a rim is a bad thing. Ive never welded a rim but I dont see why it wouldent work or be safe. As long as your a good welder then it should be just fine. If not your wheel will come apart and youll be changing your pants. :D
  5. deto
    deto
    So there is more than one way to skin a cat... The picture will tell you the direction I'm headed but my "spud" has less than .002 run out, which is good enough in my book. I will be mounting up my rim over the weekend to split it and will post a new thread on the whole process...
  6. rouye56wingnut
    rouye56wingnut
    from mn.
    If you have access to a milling machine you can use a parting saw and cut the wheel with that .That is how I cut things like oil pans and others that I want a nice clean and straight cut .
  7. 117harv
    117harv
    Looking forward to it...take lots of pics.
  8. A lot of wheels are welded together.It all depends on your skills.
