Nash Metro Auto Trans Question
Discussion in 'The Hokey Ass Message Board' started by MrFalcon62, Oct 21, 2012.
  1. MrFalcon62
    MrFalcon62
    So, my wife and I just purchased a 1961 Nash Metropolitan. She wants to rebuild the original engine, but she would like to ditch the 3 spd and put an automatic in it.
    Does anyone know what automatic ****** would fit...or can somebody direct me to somebody that might know?
    thanks
  2. R Pope
    R Pope
    Metro's never had automatics, and I don't think Austin ever used one in the A40 which was what the Metro was based on. That little peppermill engine wouldn't like the power loss though a slushbox.
  3. teejay99
    teejay99
    No trans necessary ...try large rubber band , like a model airplane .:):D
    T
  4. falconsprint63
    falconsprint63
    from Mayberry
    my family has several of these (3 currently--2 original and 1 pro-street SBF v-8 version) and i've never seen one with the orginal engine and an A/T. that's not to say they're not out there, but unless your stuck on the original motor it might be easier to swap the whole motor/trans ***embly for something else. Personally I like the idea of the thunderbird turbocoupe motor/trans--or maybe if you're feeling really frisky the toyota mini-hemi's. but there's plenty of other small RWD mills that should fit and work well.
    FWIW it's the same motor as a MG midget, but again I don't think they had a AT version of that either--the disc brakes will interchange, though.
  5. falconsprint63
    falconsprint63
    from Mayberry
    http://www.mocna.us/
    somebody here's bound to be able to help. they have had some great tech through the years.
  6. falconsprint63
    falconsprint63
    from Mayberry
  7. falconsprint63
    falconsprint63
    from Mayberry
  8. electromet
    electromet
    from Tucson, AZ
    I've seen one with an auto. I believe it was a Borg Warner T35. Same transmission used in early Datsun 510s and Austin Marinas ('73ish). I don't know if it's a direct bolt-in, but the bellhousings should match up.
    Mike
  9. Mr48chev
    As I said earlier in the thread I had one of those when I was 18 and I'd highly suggest not using the stock engine if she plans to drive it on a daily or regular basis. They don't have a rear seal on the crank shaft and relie on threads on the crankshaft that run in the block to keep the oil in the pan.
    The engines didn't don't have a lot of power with the three speeds and might not pull an automatic very well.
    I'm thinking a little 1600 out of an early Pinto or Capri with an automatic behind it would be a pretty nice engine/trans for that car and give it enough poop to get out and go. There are also a few speed goodies for those engines. It would also be one you should be able to readily find parts for.
  10. thebronc4019
    thebronc4019
    from New Jersey
  11. Rusty O'Toole
    Rusty O'Toole
    Metros used the Austin A engine. This engine was made in various versions from 1200 to 1800cc and used in various BMC cars up to the seventies.
    In 1961 they began offering an automatic trans in family sedans with this engine. Austin A60, Wolseley, Morris, MG, Riley and others. I think the last rear wheel drive car with this engine and automatic was the Austin Marina of the seventies.
    The transmission was the Borg Warner 35 which was used in most English cars that offered automatics, not to mention Studebaker, AMC and other cars. Parts are still available.
    I haven't seen an Austin Marina in years but if you could find one with an automatic it would be the easiest swap. Use the engine and trans, the engine is nearly the same as yours in external appearance but has many internal improvements like 5 main bearings and larger displacement of 1800 cc.
