Technical Nash Twin 8 Distributor
Discussion in 'Traditional Hot Rods' started by vince76, Apr 29, 2023.
  1. vince76
    vince76
    IMG_2904.JPG IMG_2914.JPG Does anybody still use the Nash Twin 8 distributors on their flatheads? I came across one and I'm wondering how or even if they are still desirable.
    Any info would be appreciated.
  2. quickchangeV8
    quickchangeV8
    The Nash Twin 8 distributor is still being used on the dual plug flathead heads, such as the Elco twin dual plug heads. This distributor is very desirable if you want to run a set of dual plug heads. On the other side of the coin there is no real increase in horsepower, if any at all in running dual plug heads, and other than making a visual statement not that many guys are using these heads anymore. The novelty seems to have worn off.
    If your distributor is in good shape it definitely has value.
    vince76 likes this.
  3. vince76
    vince76
    Thank you. I knew they used to be desirable but wasn't sure if they still were. I haven't seen any used recently.
    My distributor seems to be in good condition. I can't feel any play in the shaft.
    I suppose now the question is what's a reasonable price to ask for it.
  4. Budget36
    Budget36
    Several “how to” on posting photos. If you look below “post reply” you’ll see the “add image” icon.
    That said, so you don’t lose track of your thread, head over to the “parts for sale” section and post it there. Otherwise this post will get moved over anyways. Save the mods a few clicks;)
    Also, to not lose track of your thread, once you post it, open it again. Upper right side of the thread will give you “watch thread” and options within it to suit your needs.
    vince76 likes this.
  5. Budget36
    Budget36
    And is that a Dodge in your avatar?
  6. Gofannon
    Gofannon
    I have a Nash Twin 6 distributor going on my GMC. The trick is to remove half of the distributor cam lobes and make use of the dual coils in a single plug per cylinder application. This ensures a large dwell angle giving a healthy spark at high rpms in a high compression engine. The points need to be phased, could be fun keeping it tuned.
    RaceFink, tractorguy and vince76 like this.
  7. vince76
    vince76
    It's a 29 Oldsmobile. 4 generations inside it.
    Budget36 likes this.
  8. v8flat44
    v8flat44
    What is a Twin Eight......ignorant here
  9. vince76
    vince76
    8-cylinder engine with 2 plugs per cylinder. Nash called it a twin 8. They also made a twin 6.
  10. Dan from Oakland
    Dan from Oakland
    Hopefully you have the cap and rotor to go with it. Just saw one that sold at the Bohnams auction back east recently for around $300, and I thought that was a bargain. If you have twin spark heads thats the way to go if want the true vintage look.
    vince76 likes this.
  11. fabricator john
    fabricator john
    from venice fl.
    saw a cap on instagram for sale nos 300.00
    fabricator john
    miss you dad
  12. Gofannon
    Gofannon
    Has anyone successfully 3D printed a distributor cap? Or a rotor?
  13. stuart in mn
    stuart in mn
    I believe in one of the recent YouTube videos from Matt at Irontrap Garage he found a twin 8 distributor cap new in the box.
  14. Budget36
    Budget36
    We have one at work, the few guys that use it probably could. They’ve duplicated some interesting stuff.
    I’ve see it making a part when I come in, and still making it the next day.
    Gofannon likes this.
  15. Beanscoot
    Beanscoot
    I think it would be quite tricky to 3D print one, as the br*** inserts have to be incorporated into it.
    Plus I'm pretty sure you can't print Bakelite, which is a heat resistant plastic.
    studebakerjoe, Gofannon and Budget36 like this.
  16. Call Kevin Johnson at American Vintage Parts (706) 336 0046 and tell him Bill McKay said to call- he should have a few twin 8 caps and his prices are reasonable!
  17. vince76
    vince76
    I'm not looking for a cap. I just wanted to know if they were still used and what it might be worth.
    Thank you everyone for their input.
    Vincent
  18. banjorear
    banjorear
    Yep, cap and rotor will set you back $200-$400 hundred. Before the advent of electronic ignitions, this was the hot set up for twin plug heads.
    The little I know about the twin plug set ups, I've been told it's quite a chore to get it set up to work correctly and for little to no gain.
    Neat piece that is worth something to someone, but if you have the cap and rotor, it would be even more valuable.
