Projects Nasty Habit Willys....part 2. Rearend, firewall structure,engine mts + misc".
Discussion in 'The Hokey Ass Message Board' started by Kiwi Kev, Aug 5, 2008.
  1. I have made some progress on my Willys coupe project. Here is a link to part one. http://www.jalopyjournal.com/forum/showthread.php?t=236716
    Here is some of the stuff I got done....Rearend housing in, firewall structure done, front of frame boxed, engine mounts, Steering box moved back, made trunk hinges, front tank mount plus more.
    Here are some pics of the rearend setup. 57 Olds on original leaf springs. The ladder bars are from the 60's. I put new ends on them and made some brackets that double up as wheelie bar mounts. The rear fenders I had centered the wheels further back than stock 37 rearend so I made some lowering blocks to get the ride height I want and made them relocate the housing, they also have shock mounts added that line up with the stock ones on the frame. I have a 4.56 posi 3rd member for it and will buy some aftermarket axles later. The brakes are 62 Pontiac. I had to grind a flat spot on top of the housing flange to make them fit.
    lowering block...
  2. I made some structure in the firewall out of 1" sq tubing. I made it like this to support the Ansen swing pedals as you can't just mount them to sheetmetal. Also so I can have a clean aluminum panel on each side. Some of it that just supports the panels is real light tubing.
  3. Evel
    Evel
    Go MAN Go!!!!
    thats going to be a good time..
  4. Here are some of the parts I recently aquired for it......
    Got a hood from Hamber LB.............
    Cragar gas pedal........
    The perfect lic plate frame , it was hanging in a shed in New Zealand since the 70's and I found it on my trip. Thanks Mal! (fellow Scroungers member).......
    Got a 'gl*** trunk lid for $25 at the L A Roadster show swapmeet. I already had one but it needed many repairs so that $25 saved me alot of work.....
    Got a sbc magneto at the same swap meet for $200. I've always wanted one but that was the first one that I could afford. I got the sbc Hilborn setup in a trade locally. Maybe one day I will put it on the Willys.
    I have had one of these GT breathers for a few years and finally found it a partner at the same swapmeet.....
  5. Weasel
    Weasel
    Yesssssss!!! HAMB heaven and that Willys is so freakin' cool! When are you gonna race Skip??
  6. Royalshifter
    Royalshifter
    Moderator
    Dammmm Kev that coupe is looking ****ing mean. Great job.
  7. Here are the engine mounts. I am running it solid mounted. The mounts were given to me by a friend who said they are from a boat. I drilled the lightening holes. The front of the frame is boxed and I will be building some new stucture in the middle of the frame that includes trans crossmember that ties into the front ladder bar mounts. Also some removable mounts that tie the ****tershield to the boxing plates. Also some subrails and drive shaft loop. I am trying to keep this car very basic and simple. I could take more time tig welding everything and try to make it all perfect but that is not the goal of this build, I just want this thing running at the next Dragfest! That is why I am not removing the body. I have a mental block that says that will add a year to the build.
  8. Here are the new trunk hinges made from aluminum. They are bolted to brackets that are welded to the expanded metal, the expanded metal is riveted to the inside of the decklid and will later be fibegl***ed on. The rivets that protrude on the other side will be ground down below the surface and minor fibergl*** repair will finish the installation.
    Here is the beginning of finishing the cowl where the firewall was cut off.....
    Here is the Eelco tank mount. Tank was given to me by Hamber, friend and co-worker Hot Rod Willie. Tank brackets are home made. Tanks are so overdone lately but they will always be a pure item on a 60's style drag/street car.
    I love the no grill compe***ion look of this car so I hope to end up with something similar.....
  9. ro51_hemi
    ro51_hemi
    from York,Pa
  10. Got my seating position figured out. I moved the steering box back a couple of inches and made a wedge to go under it and bring the wheel down a little. Bent the shifter until it was in a comfortable position, come on Dragfest!!.........
    -Brent- likes this.
  11. poorboy
    poorboy
    i'm lovin the look of this car! and as always, sweet garage!
  12. Muttley
    Muttley
    Looking good! I see you found a CRAGAR pedal (I had mine first :p).
  13. Kev,
    That photo is GREAT ! Keep up the good work.
    CBB
  14. VNCduke
    VNCduke
    from Washougal
  15. OL 55
    OL 55
    Looking good Kevin! Man you're making me look like a SLACKER !! I wish I had as much drive as you, my OL 55 would be back on the road in no time !! :D
  16. The Brudwich
    The Brudwich
    Looks great Kev! Let me know when you need a driveshaft. I'd love to contribute something to your Willys!
  17. Rckt98
    Rckt98
    Looking good Kev. See you at Bonneville.
    Russell
  18. FinnishFireball
    FinnishFireball
  19. HOTRODSURFER
    HOTRODSURFER
    from HATBORO,PA
    lookin good!! nice work kev
  20. 39sledge
    39sledge
    nice job you and royel should start a willys resto shop you both would clean up.car looks great.
  21. Loks great Kev!
    Awesome work!
    Mike, Dyan & Peanut were over before and me and Mike got talking about this car and wondered how you were going!
    Looks awesome!
  22. Don Moyer
    Don Moyer
    I really like the way this is going together...some day I hope we line up for a grudge match...Don
  23. pan-dragger
    pan-dragger
  24. abone1930
    abone1930
    Awesome willy project. Alway lookin for one of those at the end of the rainbow. I need the gold to buy a hull
  25. striper
    striper
    You clever *******
  26. enloe
    enloe
    from east , tn.
  27. D.W.
    D.W.
    from Austin Tx.
    Oh man! This is gettin good!
  28. continentaljohn
    continentaljohn
  29. 327-365hp
    327-365hp
    from Mass
    Always look forward to your posts Kev. That car is really coming along, you make it look easy. Love the plate frame with the Willys on it, it's perfect for your car. They must be rare if you didn't already have one? I tried to buy one on ebay, big $$
  30. Dirty2
    Dirty2
