Navarro's O streamliner record. Any half V8 Engine details?
Discussion in 'The Hokey Ass Message Board' started by Kevin Lee, Mar 5, 2004.
  1. Kevin Lee
    Kevin Lee
    Super Moderator
    Just thinking about Barney Navarro's 1950 record. Any particulars regarding how he blocked off four cylinders to run that class? What cylinders would you run? I assume that record is long gone by now - but would half a V8 (Flathead) be eligible for HOP UP's 100mph club?
  2. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    do the other pistons have to be "dead", could'nt you use them to supercharge the other 4? [​IMG]
  3. Kevin Lee
    Kevin Lee
    Super Moderator
    Oh, don't think I haven't already thought of that. Reed valves, radically trimmed down skirts, drilled out "T-man" piston rods, I just wonder if you could reduce the weight and friction enough to make it a benefit... Bruce L. had some interesting things to say about this. I'll dig them up Monday, I'm out for the weekend.
  4. Remember Fred Larsen (Mooneyes Fame) set a record with a half V8 which I think put the his car into a 124 cu. in. class for Bonneville back in the late to early 60's.
  5. racer5c
    racer5c
    A guy named Ron Hottels from around Milwaukee buit engines called Sesco's which were chevy and ford v-8s cut in half made into inline 4 cylinders for Midgets in the 70's Their have also been quite a few v-4's made for Midget racing most notably by SCAT in Redondo Beach CA. I think he sold the rights to his V-4 to Arlen Ness to use for Motorcycles.
  6. Tackett
    Tackett
    I saw some of those V-4's in off-road cars afew years ago at the Baja 100.
  7. Unkl Ian
    Unkl Ian
    An external blower would be more efficient.
    And you could adjust boost levels by changing pulley sizes.
    The Eaton blowers used on latemodels are very compact,and probably very efficient.
  8. metalshapes
    metalshapes
    It is still an interesting idea.
    You could use the outside 2 cylinders of one bank and the inside 2 of the other, to keep the pulses even.
    Being a 4 stroke you would have 2 induction strokes on a dead cylinder for every induction stroke on a live one.
    Has this ever been tried before?
    Would such an engine need special balancing?
    Or would it be OK if you would keep all 8 pistons the same?
  9. laverda
    laverda
    The latest Street Rodder has a section featuring 4 salt flat cars. One runs the half V8 with a turbo. The 'power' side has a traditional valve cover and the 'blocked' side is a flat head head! Gets some double takes! Let me know if you would like me to scan and post.
    Later,
    papa al
  10. [ QUOTE ]
    [/ QUOTE ]
    I worked with Ron on his Half V8's and his V8 Suzuki midget racers!!! [​IMG]
    I had the priveledge to work the pits for Mel Kenyon and Greg Nelson! Although Stan Fox didn't run a Sesco we worked on his cars and he loved test driving the Sesco's any chance that he would get! [​IMG]
    Rons affordable creations were designed and built in his basement of his house in Hubertus Wisconsin and knocked Offenhauser out of the competitive ranks with its inexpensive horsepower! [​IMG]
    I believe he did sell the rights..., but I don't know to who??? [​IMG]
    Mark
