1952-59 Ford Nearly ready for paint on the 55 and a big decision to make
Discussion in 'Off Topic Hot Rods & Customs' started by bashnaka, May 5, 2014.
  1. bashnaka
    bashnaka
    from england
    just about there now and the more i look at it the more i want to get rid of the vent windows in the front and convert it to one piece gl*** ..any thoughts on it ar tips on how best to do it would be welcome
    on this one i have decided to get rid of the chrome trim and the rocker will be channeled to allow the exhaust to exit cleanly
    this shows the rad in place and the top will have a cover on it to look like a very clean slam panel
  2. acj
    acj
    You will get a lot of wind noise.....with the window down.
  3. bashnaka
    bashnaka
    from england
    Thats ok i will just turn the Johny Cash up louder
  4. Rui
    Rui
    Cant help but I dig the exhaust. I'm gonna go with the same option on my car.
  5. Hunter73
    Hunter73
    The vent window really helps with directing the air if you're not running AC.
  6. bashnaka
    bashnaka
    from england
    Hahahahahahahaha air con in England ....Open the window and turn the heater up
    er up
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    That is the one thing I like about older cars is the ability to direct the air where I want it with the vent windows,with a one piece if you crack down a window it blows across the top of your head and messes with your hair and blows bugs in your face,probably one of the dumbest ideas the car companies came up with.
  8. rick55
    rick55
    I am with you Jeff, but it certainly wouldn't be the hardest job to convert. Just fix some bailey channel on the front edge of the door modify a rear gl*** door run bracket to fix the bottom run of the gl***. You will need to run power windows. The hard part will be fixing the exposed section of the bailey channel as there are no fixings provided in this section of the inner door. It certainly can be done. A couple of friends have fitted one piece gl*** to the front of 1952 F1 pickup and a 1948 Mercury coupe.
    You will need a good heater setup as you won't have the benefit of the vent windows.
  9. bashnaka
    bashnaka
    from england
    If im honest the airflow comfort side of things never entered my head i just want the car to look as nice as possible and living in the northern part of England a good heater ( it has one ) is way more important than ventilation and it rains a lot here . also im a motorcyclist so i like a bit of wind in the face
  10. flyboy89
    flyboy89
    from So. Cal.
    I would stick with the factory look. Not a big fan of the one piece gl*** on the doors for vintage cars. My opinion and you know how opinions go.
  11. bashnaka
    bashnaka
    from england
    Yea i looked at it today from all angles and i think the vents will stay on the car
  12. rick55
    rick55
    Good choice! The front windows are big but would be huge without the vent. Why fix what ain't broke.
