Nedd a wiring diagram '58 Chevy igition
Discussion in 'The Hokey Ass Message Board' started by raven, Nov 14, 2006.
  1. raven
    raven
    I need a simple wiring diagram for a '58 Chvey truck ignition.
    Simple and sweet, nothing fancy.
    Thanks,
    r
  2. Tony Daytona
    Tony Daytona
    I just did the engine harness and forward lamp harness in my 58 Chevy Biscayne. I have the wiring diagrams for that at home if they would help. Under the dash wasnt too bad, just cramped for space as usual.
  3. raven
    raven
    I just need how the back of the ignition switch is wired.
    r
  4. Tony Daytona
    Tony Daytona
    I don't remember if it had that diagram in it or not, but I'll look when I get home. 4 wires into it right?
  5. raven
    raven
    Not sure. I haven't looked at it yet.
    I will tonight.
    r
  6. squirrel
  7. raven
    raven
    8 cylinder.
    r
  8. squirrel
    should be like this
    pink is for gages and stuff that run when the key is on
    brown to the ballast resistor for ignition power
    violet for starter solenoid
    red is power in
    this is the for the V8 switch, the 6 cyl switch does not have a "start" position and has different resistor bypass wiring
  9. CURIOUS RASH
    CURIOUS RASH
    Classified's Moderator
