Need 283 Info Quick!!
Discussion in 'The Hokey Ass Message Board' started by 54HellAir, Jan 10, 2007.
  1. 54HellAir
    54HellAir
    yo..does anyone know if a front mount 283 motor will match up in a 54 chev??? I have a chance to buy one but its the block with no side mounts....has anyone done/seen this??? thanks
  2. brownbagg
    brownbagg
    from grand bay
    I have seen them in 55 all the time.
  3. Royalshifter
    Royalshifter
    Moderator
    Are you sure it is a 283 with no side mounts?
  4. magnet
    magnet
    usually the 265 had front mounts and the 283's were side... i think.
  5. Down South Racer
    Down South Racer
    1957 Chevrolet 283s did not have provisions for side mounts. The side mounts came in 1958.
  6. enjenjo
    enjenjo
    from swanton oh
    57 283 had no side mounts. It will fit fine, but you have to use a mid mount of some type to keep the engine from rocking. in 53 and 54, Chevy installed 265s in 53 and 54 Chevys for road testing.
  7. magnet
    magnet
    Ahhh learn somethig new every day :)
  8. 54HellAir
    54HellAir
    thanks for the quick replies...can you buy mid mounts or do you have to fab something??? Is this a tough install???
  9. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Early v-8 Vettes had front mounts, and the frame and suspension was essentially the same as a early 50s convertible sedan.
  10. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    Speedway Motors should be able to fix you up with about every thing you need. In the 60s this swap was about as common as dirt and about as easy as falling off a log.
