need '55 F-100 help
Discussion in 'The Hokey Ass Message Board' started by draggin breath, Mar 22, 2009.
  1. draggin breath
    draggin breath
    What power steering box can I use with the stock axle? Has anyone had problems using the Speedway disc brake kit?
  2. ugotpk
    ugotpk
    Hi Draggin,
    Call Bob's F100s. They will fill you in.
  3. okiedokie
    okiedokie
    from Ok
  4. Huntfamily53
    Huntfamily53
    from AZ
    Toyota PS box from a '80-84 Toyota 4x4 truck. Probably the best mod out there for these trucks. There are a ton of articles on it Here are a few:
    http://www.ford-trucks.com/article/...ta_Steering_Box_Swap_For_19481960_Trucks.html
    http://www.cl***icperform.com/tech_articles/F-100_Steering/F-100_Steering.htm
    I plan on doing this this summer.
    I am also going with the Speedway kit...seems to be the best deal out there for all the parts you need.
    http://www.speedwaymotors.com/Deluxe-Disc-Brake-Kits-1948-1956-Ford-1and2-Ton-Pick-Up,4621.html
    I am going with the 5 on 5 1/2 kit.
    +1 on okiedokie's comments that website is the best for info on this era of trucks.
    Good Luck!
  5. Dan A
    Dan A
    from Mesa Az.
    Used the Toyota 4x4 setup on mine, works great.
  6. 53floored
    53floored
    from kansas
    I just got done putting that kit on my truck its simple to install and it uses the stock backing plate holes to mount the brake calipers and you just unbolt the hub from the spindle and install the bearing on the spindle (yes its a tight fit I used a 3 lb sledge and a 2x4 block to tap it on all the way and the rotor sets on that and rotates on that.
