Need a Ford part number deciphered
Discussion in 'The Hokey Ass Message Board' started by raven, Jun 10, 2010.
  1. raven
    raven
    Have an 8.8 and am looking to get the ring gear part number decoded.
    This is stamped on the ring gear: E3TW DA 1139 5HD.
    I have googled it but have come up empty.
    Anyone?
    r
  2. Deuces
    Deuces
    This is easy!! The ring and pinion set you have is a 3.55 :) I installed the same set of gears in my '91 5.0L er (scratch that) 5.8L car. :D
  3. Deuces
    Deuces
    .......It's also a heavy duty set from an F-150 or a Ranger pick'em up truck.... '95 vintage I believe...... Or 2003??
  4. raven
    raven
    Man, that was quick. I was told it was out of a truck.
    Thanks.
    r
  5. Deuces
    Deuces
    Your welcome !!! :) By the way, that's a great gear set for the street if you have a T-5 manual trans.
  6. PowerByFord
    PowerByFord
    from stigler,ok
  7. Deuces
    Deuces
    For those who want to know what ratio ring and pinion set you have, have a calculator handy.. Count the number of teeth you have on the pinion gear and the same with the ring gear. In Ravens case, his pinion gear has 11 teeth and the ring gear has 39 teeth. Divide 39 by 11 and you get a 3.545:1 ratio. Round that off to the next highest number and you get 3.55:1 :)
  8. Deuces
    Deuces
    I thought the 8.8 didn't come out till '86.....
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    In Fordspeak part number prefixes:
    "E" is 1980s...B-50s, C-60s, D-70s
    Numeral "3" is year of the decade
    "TW" indicates vehicle, various letter code combinations indicate models of cars, pickups, trucks, vans.etc.
  10. PowerByFord
    PowerByFord
    from stigler,ok
    yep..Pasadena is right.I BELIEVE they came out in the seventies in the smaller cars.Anyone care to chime in?curious myself...
  11. Deuces
    Deuces
    Only way I could tell is looking at a picture of the "diff" cover.... So, how about it Raven.... Could you snap a picture of it please and post it??? Thanks!
  12. Deuces
    Deuces
    There was also a 7.5" rear axle that came out before the 8.8".... But I don't think Ford had a 3.55 gear for that one... The 7.5's did have a 3.45 gear setup....
  13. R Pope
    R Pope
    I have a '79 Mustang with a 3.55 7.5 rear. It was a turbo 4 originally.
  14. raven
    raven
    This one is the ten bolt rear cover with the two cut outs in each lower corner.
    Great set for the street, but I need it for the strip.
    Anyone instrested in a a narrowed heavy duty 8.8 with new brakes and a 3.55?
    r
  15. Deuces
    Deuces
    Why not just change the gears to whatever you want to use??... Next inline from the 3.55's are the 3.73's, 4.10, 4.56's and I think a 5.14 gear set also....... Check with Ford Performance Parts on the net.
  16. falconsprint63
    falconsprint63
    from Mayberry
    83
    C denotes 60's (number is the year)
    D 70's
    E 80's
    etc
