Technical Need a new starter
Discussion in 'The Hokey Ass Message Board' started by Babyboomerboy, Jul 23, 2024.
  1. Babyboomerboy
    Babyboomerboy
    I need a new starter for my 1950 Ford Tudor. I notice that some of the starters for sale are without the drive bendix. Can I use the bendex from the old starter or should I get a starter with the drive included? Also any suggestions on the best place to get this starter? Thanks
  2. New starter huh? I bet that’ll umm, ignite your fire.
    JohnLewis likes this.
  3. JohnLewis
    JohnLewis
    Wouldn't that be the coil.^
  4. alanp561
    alanp561
    Third Gen Automotive
  5. JohnLewis
    JohnLewis
    I'd ***ume if they sell it without the bendix, you are suppose to use your old one.
  6. brando1956
    brando1956
    You can reuse the old one, but keep in mind that it is a common failure point. If you don't mind pulling it again, go for it. Are you sure that a worn Bendix isn't part of the problem? Not familiar with your starter, but if it's like some of the old Ford tractors I've worked on, the Bendix sticks out about 6 inches and the end of the shaft rides in a bushing in the block. That differs from more common starters that have their drive end bushings in the starter nosecone. If that bushing in the block is worn out that can cause a problem. If your setup is different disregard, but I've found Ol' Henry used a lot of the same parts in his tractors as his cars.
    Could also be more costly if you buy the starter alone and the Bendix later, especially if you have to pay shipping.
    JohnLewis, skooch and Toms Dogs like this.
  7. alchemy
    alchemy
    If you are buying a new starter, you might as well get one with a new bendix. And don’t get the modern bendix replacement, I’ve read that they can be troublesome.
    JohnLewis and alanp561 like this.
  8. Babyboomerboy
    Babyboomerboy
    Thank you all for your replies. It looks like I need a new starter with the OEM bendix. Does anyone know where I can find a new starter and bendix that is not the modern bendix?
