Technical Need a shop with a big milling machine, recommendation?
Discussion in 'The Hokey Ass Message Board' started by Barn Find, Jun 26, 2015.
  1. Barn Find
    Barn Find
    from Missouri
    I want to mill a flywheel housing that is 19" wide. Shops around here can only handle heads that are 14" wide maximum. I can ship the housing anywhere that has the right equipment. Can you recommend anyone?
  2. dreracecar
    dreracecar
    from so-cal
    Explain what it is you are trying to do/machine, it would help a bunch
  3. RichFox
    RichFox
    Are you going to automotive shops? Or general machine shops? You might want to branch out a little.
  4. gimpyshotrods
    gimpyshotrods
    Yeah, try a general machine shop. I have had stuff worked way bigger than that.
  5. DDDenny
    Try diesel repair shops.
    Google Blanchard grinding.
  6. RichFox
    RichFox
    Here is one of my friends CNC mills with a 32 Ford frame stored on the table. I'll bet he could mill your bellhousing. But you are to far away. There are some good things about living in California. 11102670_1085241054825542_2306994482833428545_n.jpg
  7. Shaggy
    Shaggy
    from Sultan, WA
    One of my coworkers has his hands(family business) in a machineshop in Missouri, their bread and ****er is oil pipeline stuff, but he's done a lot of 1-off tractor pulling stuff including random brand custom cylinder heads. Depending on what you want he'd be the guy to talk to
  8. dreracecar
    dreracecar
    from so-cal
    must not be an emergency
  9. EXPLAIN,,,what you want might be done on a lathe.
  10. DDDenny
    Sorry, I thought you wanted a flywheel machined.
  11. Phil1934
    Phil1934
    I shortened a factory aluminum bellhousing on a lathe. Cutting made a deafening screeching noise, but did ok.
  12. Barn Find
    Barn Find
    from Missouri
    Thanks for the replies. I was having problems cracking flexplates. I just wanted to make sure the flywheel housing is not warped. I think it's an unlikely cause, but am desperate to eliminate possible problems.
  13. Where are you in the state. Which face do you want milled engine block I am ***uming. Are you calling a bell housing a fly wheel housing?
    Before it got chucked up and cut I would make u sure that it needed cutting. Mill is no necessary for that. That said I could get it done here no problem, either sneak it into my old place of employ or take it to the tractor pull shop up the road here a bit and have them face it if it needs it.
  14. saltflats
    saltflats
    from Missouri
    Have you tried Richard Lohse in Columbia?
  15. Barn Find
    Barn Find
    from Missouri
    I'll do just that. My son is in daycare right by Richard's shop. The door to his shop was hanging open the other day, and I almost stopped. I should have, and I will.
  16. Bert Kollar
    Bert Kollar
    If you want to ship it to Ohio my friend has a Bullard that will do that. He just squared up a transmission case for my buddy. Call me at 440 231 2318 Bert
  17. dreracecar
    dreracecar
    from so-cal
    Usually stuff like that gets Blanchard ground to get both surfaces parallel.
  18. where i used to work had a 36" Blanchard , that would be ideal for that. i certainly found a lot of uses for it
  19. Dan Timberlake
    Dan Timberlake
    Before machining anything I'd mount a dial indicator on the crank and sweep the flywheel housing's mounting face and the bore.
    It might take require making an angle iron adapter or something.
    1-SHOT likes this.
  20. 1-SHOT
    1-SHOT
    from Denton
    Like Dan ,said take a dial indicator and then you may need offset dowels to correct a problem. Frank
  21. seb fontana
    seb fontana
    from ct
    They make neat flower pots........
  22. FrozenMerc
    FrozenMerc
    Just exactly how big of a lathe do you need???
    gimpyshotrods and saltflats like this.
