Hot Rods Need a source '32 FORD upholstery panels
Discussion in 'The Hokey Ass Message Board' started by seabeecmc, Jul 23, 2023.
  1. seabeecmc
    seabeecmc
    My '32 5 window had a LeBaron Bonney upholstery installed when I purchased it. I sold that interior to a fellow HAMBer. Now I am looking for patterns to fabricate door and kick panels etc. Does anyone know of a source? Regards, Ron
  2. alchemy
    alchemy
    Do you have the door and cowl? Can’t you make your own patterns from them? Might even be a better fit than someone else’s.
    warhorseracing, aussie57wag and X38 like this.
  3. nochop
    nochop
    from norcal
    I was looking for trunk panels….everybody here told me to man up and make my own……..anybody want to by a bunch of upholstery boards…….suitable for glove boxes?
    seabeecmc, 60 Special and 19Eddy30 like this.
  4. swifty
    swifty
    Did your car have trunk panels before? I dislike the way that trimmers do the trunk and turn it into a box reducing the capacity by about 25%. I guess I believe in being practical not pretty and I can get a lot of groceries in my 32 trunk. But we use our hot rods as dailies, not Coffee & Cruise cars. Talk to your trimmer about what he needs, mine likes 1/8" less so trim can wrap around the edges.
    chevyfordman likes this.
  5. 19Eddy30
    19Eddy30
    from VA
    Looking for compleat Original style also,,I like the Original, Far as I know was only Two companies, both gone now ,
  6. nochop
    nochop
    from norcal
    Nope, all my original stuff is long gone. I’m gonna to be the “trimmer “.
  7. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Have made and covered several of the trunk panels for my deuce roadsters to save money. Most of the time I have just used the same carpet as the interior and cut some rubber matting for the floor. I use large size butcher paper or sometimes I have large sheets of brown wrapping material to make the patterns. For the panels I like 1/8 inch Luan plywood. I've done a few complete interiors in my deuce's when I was pinched for cash. I had a good local upholstery shop that helped with the sewing for me.
    warhorseracing and nochop like this.
  8. nochop
    nochop
    from norcal
    Where did you source the rubber mat material?
  9. 325w
    325w
    I used cardboard. In the trunk you just make one pattern. Doors one pattern. Kick panel one pattern. I used 1/8 inch ABS black plastic panel.
    da34guy likes this.
  10. deathrowdave
    deathrowdave
    from NKy
    I have LaBaron / Bonney panel patterns for 3 windows .
    nochop likes this.
  11. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Rubber mat from Antique Auto Restoration And Supply (I need to double check the name) I use the 1/8 inch thick mat with small pyramids in the surface. I've used it in several cars. I buy the 48th inch width. I will confirm the company name and part number in the morning,
    Jacksmith and nochop like this.
  12. swifty
    swifty
    If you make your own door cards, kick panel cards and those for beside and behind your seat you are not paying trimmers rates for him to do them. I even fitted the clips for my door cards. I used 1mm alloy sheet for mine, not affected by water and light as. As @nochop is doing his own t******* then he will save heaps and not end up in trimmers jail either. I lined the whole inside of the car, trunk included with an Aussie version of Dynamat before it went to the trimmer.
    Just Gary likes this.
  13. nochop
    nochop
    from norcal
    Door and kicks are a piece of cake……trunks and headliners……but I’ll get it
  14. nochop
    nochop
    from norcal
    https://restorationstuff.com/
    Found them
  15. seabeecmc
    seabeecmc
  16. nochop
    nochop
    from norcal
  17. seabeecmc
    seabeecmc
    “Time is more valuable than money. You can get more money, but you cannot get more time.”
    justpassinthru likes this.
  18. K13
    K13
    I guarantee those are coming from a supplier in the US, being shipped to Canada and then reshipped back down to you. Don't trust their dates either I am going through it with their Chevy division trying to get parts.
  19. seabeecmc
    seabeecmc
    K13, THANKS for the heads up. Ron
  20. Bert Kollar
    Bert Kollar
    My local gl*** shop buys 4' x 8' sheets of corrugated for patterns. I buy a couple sheets and make my own patterns. Very easy. My upholsterer uses mine to do my cars
  21. hotrodA
    hotrodA
    Found this at Lowe’s for my 32 Tudor. Around $60. Nice pebble grain and heavy duty.
    warhorseracing likes this.
  22. hotrodA
    hotrodA
    Found this at Lowe’s for my 32 Tudor. Around $50. Nice pebble grain and heavy duty. The one roll did the whole sedan floor with some left over. Using it in my roadster.
    View attachment 5795231 View attachment 5795232
  23. nochop
    nochop
    from norcal
