Technical Need a Source for Pipe Reducer Bushings
Discussion in 'The Hokey Ass Message Board' started by Root66, Apr 8, 2014.
  1. Root66
    Root66
    from Norcal
    Not the typical hardware store type but the type shown at the bottom of the pic below.
  2. badsco
    badsco
    I have come across steel versions of those with electrical conduit, specifically around explosion proof and rugged/environmental boxes and fittings. Hope that helps.
  3. 325w
    325w
    Which size you need?
  4. Are they npt? They look like conduit bushings but those are a straight thread. If they're npt I'd like a source as well
  5. EARL"S,,maybe ?
  6. badsco
    badsco
  7. srs1
    srs1
    ebay has several
  8. DERPR30
    DERPR30
    from HARVEY LA
    Badsco is correct face or flush bushings npt can be found at any good plumbing supply these look like br*** but are available in many types of materials
  9. Root66
    Root66
    from Norcal
    That's the right idea but the wrong size...I need 1/2" NPT to 1/8" NPT and 3/8" NPT to 1/8" NPT. At least I now know what they're called.
  10. Root66
    Root66
    from Norcal
    Link?
  11. d2_willys
    d2_willys
    from Kansas
    ACE is the place
  12. 35WINDOW
    35WINDOW
  13. Those sizes may be tough to find; as a worst-case, you could get solid br*** plugs and drill/tap them for the 1/8" fittings. What you'll usually find in these sizes is ones with a hex head to allow tightening the outside thread separately. Trying to use the 1/8" to tighten both will usually result in a stripped 1/8" thread.
    I've used the hex-head types, installed them, then cut/ground the hex off. You might have to tap the 1/8" a bit deeper after doing this.
  14. trbomax
    trbomax
    you can get allen socket head br*** pipe plugs.these will have the advantage of centering the hole that you drill thru the center.
