Hot Rods Need a stock A sedan measurement...
Discussion in 'The Hokey Ass Message Board' started by Tim, Dec 5, 2016.
  1. Tim
    Tim
    from KCMO
    Awefully specific question, but if any ones got a stock wheel base 29 ford Tudor could you look at something for me?
    It looks like the center of my rear wheels lines up with this second pinstripe behind the back side window. I think I've got it sitting on the frame correctly but I threw a fender on and it doesn't looks quite right. Figure this would tell me if it's me or the fender that's tweaked a bit lol
    Thanks guys :)
  2. 34FordConv
    34FordConv
    I don't know what to tell you, that's not a real good measurement point and eyeballing isn't a real measurement. :D
    Does the two frame mount holes at the front door posts line up?
  3. Tim
    Tim
    from KCMO
    Lol true. I guess I'm asking for an eye ball measurement then. I laid a yard stick from point to point to get that estimate. All the holes in what's left of my subframe are lined up right on the money.
  4. oj
    oj
    From the bolt hole for the crossmember under the drivers' seat the rear will be about 31 5/8ths
    Tim likes this.
  5. 34FordConv
    34FordConv
    Well if all the mount holes line up there really isn't any adjustment to the for and aft on the frame.
    My 29 Tudor looks close to that (Eyeballing it) i guess.
    Tim likes this.
  6. Tim
    Tim
    from KCMO
    Thanks for lending me your eye balls :)
  7. 19Eddy30
    19Eddy30
    from VA
    IMG_0803.PNG This might help , cannot put my hands on my book that has all the measurements
    Tim likes this.
  8. Tim
    Tim
    from KCMO
    It does actualy.
    If you look at those types of photos you see the arch of the pickup and Tudor rear fenders are different than the coupes and roadsters.
    The way it sat around the tire differently than a coupes would was messing with my head
  9. Just Gary
    Just Gary
    On my '28 tudor, the axle centerline & fender peak are both aligned directly straight down from the back edge of the rear window opening. I think your axle is a little too far back.
  10. Just Gary
    Just Gary
    Tim, I have a Ford factory diagram that will help answer your question, but it's too big to post. Message me your email address and I'll email it to you. :)
    Tim likes this.
  11. Tim
    Tim
    from KCMO
    Wow that is quite a bit different! I'll pm you my email address.
  12. 34FordConv
    34FordConv
    I would suppose it really depends on how you look at it, with the car on the ground, what kind of rake it has etc. If I use the belt line as a level then my axle center line is pretty even with the front edge of the rear window as in the picture posted by Just Gary.
  13. Tim
    Tim
    from KCMO
    Another excellent point
