Need advice: best way to paint clear on bare metal
Discussion in 'The Hokey Ass Message Board' started by michael_cini, Oct 31, 2010.
  1. michael_cini
    michael_cini
    I have a valve cover that I have stripped down to bare metal with stripper and wire brush. What is the best way/product to use to put a clear high-temp coat on it? Hopefully rattle can.
    Thanks.
    Michael
  2. squirrel
    steel? aluminum?
  3. Well first you'll have to pickle it. As far as I know there is no self etching clear. Muratic acid mixed 1/1 with water.
    Then the clear still won't stick, it needs to have something besides bare metal to stick to IE primer.
  4. michael_cini
    michael_cini
    steel. sorry.
  5. michael_cini
    michael_cini
    i have seen a few kustoms with bare metal exteriors with just a clear coat. there must be a way...right?
  6. The Hank
    The Hank
    from CO
    Glad I seen this thread , I have some 18g sheet metal I'M making some trim pieces from , I plan to polish them and want to clear them as well . I have auto clear coat left from when I painted my car. I hope it works.
  7. 510madmav
    510madmav
    Rub motor oil on it
  8. michael_cini
    michael_cini
    r u serious?
  9. Acme Speed Shop
    Acme Speed Shop
    MODERATOR
    from so cal
    Eastwood sells a clear for bare metal that works really weel. I do not know what temp it is rated for but it works on bare steel.
    I think it is called diamond clear.
  10. In before the rest. Gibbs oil.
  11. Por 15 also sells a clear. Don't know how it works though.
  12. AA/Fuel34fordpu
    AA/Fuel34fordpu
    On my sheet matal scoop. I use paint thinner to clean the metal and let it dry. Then I bought some duplacolor pre mixed clear. I put it in the gun and sprayed it. I put on 12 coats the wet sanded and buffed. It worked out real nice I think and Im happy.
  13. 97
    97
  14. BOWTIE BROWN
    BOWTIE BROWN
    vht.clear
    my $.02
  15. michael_cini
    michael_cini
    Thanks for all of the tips guys. I did look into the VHT paint. But they suggest using it over the paint. Not instead of. Here is a link to a forum on the VHT site where a rep from the company says they don't suggest using it on bare metal.
  16. michael_cini
    michael_cini
  17. MR. FORD
    MR. FORD
    from Austin, TX
    Well, I have been keeping an entire car in bare metal for the last two years. Gibbs works well, but water does not just run right off. Just like anything else, you have to stay on top of it. Eastwood diamond clear seems great at first, but after 2 years and extremely clean metal to start with, everything I used it on is now rusting UNDER the clear coat.
  18. Del Swanson
    Del Swanson
    from Racine, WI
    I've seen urethane clear sprayed after an adhesion promoter with good results. The metal must be really clean.
