need advice on 'bolt' on IFS for 57 Chevy 3100
Discussion in 'The Hokey Ass Message Board' started by revedup57, Nov 23, 2011.
  1. revedup57
    revedup57
    Hey guys, is there anything such as just a "bolt on" IFS for a 57 3100 series; or do will I have to do fab. and welding? Also, can someone tell me what donor trucks I can use for the conversion, because I cant afford to buy a new kit, like Mustang II? I'm not the greatest welder, so doing a clip is out. Thanks.
  2. F&J
    F&J
    List the gains you want to get by IFS, first.
  3. need louvers ?
    need louvers ?
    I'd look into a Jag XJ6. It isn't going to bolt in, but you could do all the fitting and pay a welder to come out and do the deed... Check the search function, lots about this one.
  4. Swell 58
    Swell 58
    from Batavia IL
    Look into Crown victoria front crossmember suspension assemblies, from 2003 and up. it is completly modular and all aluminum with rack and pinion steering. you can pick up a complete one for around 250, or pick up an entire crown vic for less the a 1000.
  5. jimvette59
    jimvette59
    Howbout a 53 chevy ? You may have to weld some brackets to bolt it in or a C1 corvette front end.
  6. squirrel
    the most sensible answer I've ever heard to this question....
  7. Nothing bolt on about hot rodding, that is a myth.
    Learn to weld is my only answer. Early C-10 is a good donar for IFS for your old truck BTW. They are cheap and you will need to learn to weld. if you cannot weld well tack it together and get someone else to weld it for you if you don't want to learn.
  8. squirrel
    63-up C10 suspension would be a good donor if you are not trying to lower the truck too much, they're wide and kind of hard to get a truck with a straight frame like yours to sit on a suspension that fits a truck with a frame that kicks up in front and is narrower.
    Or maybe your'e talking about the torsion bar 60-62 setup?
  9. 53sled
    53sled
    from KCMO
  10. If you would, read this: Bolt in Dodge Dakota based IFS
    Then comment on my forum as to what you are truly looking for. Forum
    I am looking for guys like yourself for input as to what you expect out of a kit like this.
    Thanks.
  11. olpaul
    olpaul
    I welded a Volare under my 58 3100 Apache. You can make the axle and springs work too. The grey beards can give you the good parts to use.
  12. Steve Ray
    Steve Ray
    Nothing wrong with a properly set up straight axle.
