need advice on smoothing weldsi
Discussion in 'The Hokey Ass Message Board' started by Kev2004, May 30, 2010.
  1. Kev2004
    Kev2004
    I have a t bucket and the welds On the dropped tube axle and hairpin radius arms Are good welds but need smoothed out a little. I was thinking of hand filing them and using a filler either bondo or maybe a metal filler to smooth them. Any advice would be great.
  2. just don't grind/file away too much of the weld....you want to retain the strength
    pictures?
  3. oj
    oj
    Pics would help, how you go about dressing them up depends on the weld method. If it is an option i would probably take it to somebody that TIG welds and let them make a p*** over it, that might clean it up. MIG welds are terrible hard, you'll have a hell'uva time taking a file to it. Post a pic, somebody on here has dealt with exactly what you are doing and they'll fix you right up.
  4. need louvers ?
    need louvers ?
    A fairly large diameter rotary file on a air die grinder should turn the trick. Don't go crazy removing material, just smooth out whats there, and be careful of undercutting the brackets. When I say "fairly large" I mean something in the range of 3/8" or larger.
  5. Kev2004
    Kev2004
    It is mig. I can't seem to get the pics to upload.
  6. 29nash
    29nash
    from colorado
    Removing material from a structural weld weakens it; therefore I recommend you don't...........
  7. Pete1
    Pete1
    from Wa.
    For what it is worth, NO racing ***ociation will allow grinding on structural welds.
    There must be some reason for that, huh.
  8. Kev2004
    Kev2004
    I am just gonna hand file a couple of spots that are higher than the rest of the weld. Looks like the weld ran a little bit.
  9. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Flapper disc and a 4 inch grinder......
  10. RopeSeals???
    RopeSeals???
    I wouldn't grind them to make 'em pretty, use some Polyester Putty instead...
  11. Kev2004
    Kev2004
    I see Eastwood has some putty that sets up hard enough to drill and tap and is sandable.
  12. PackRatWrecker
    PackRatWrecker
    from Kansas
    If you are just softening a couple high spots, I'd try a flap wheel. I've seen them as small as 2" with a 1/4" stem, for die grinders, or the normal 4-4 1/2' variety. I've also seen them for Dremel tools, but I imagine they would deplete pretty quickly.
  13. PackRatWrecker
    PackRatWrecker
    from Kansas
    Is there an echo in here?
  14. Kev2004
    Kev2004
    Here are the pics of the welds
  15. kelzweld
    kelzweld
    I'd usually say if you have to ask how...don't. But seeing as how those lumps are just the stop/starts, it can't hurt if you bring them down to the height of the rest of the weld without touching the parent metal. A file should take care of that in no time at all.
