Hot Rods Need Advice
Discussion in 'The Hokey Ass Message Board' started by 56 Dodge, Nov 11, 2025.
  1. 56 Dodge
    56 Dodge
    from Ohio
    I got a 51 ford truck with 34 wishbone suicide front end 460 ford. Vega cross steer, new king pins. I cant steer it it takes all of my upper body strenght to steer it down the driveway. I'd love to put some sort of a electric power steering rack and pinion on it but everwhere I've checked I need a ECU and all kinds of modules. Please advise and thank you very much!
  2. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    How were the pins fitted?
    ***uming you had no prob before,.
  3. 56 Dodge
    56 Dodge
    from Ohio
    New build! never on the road until this spring. with no weight steers easy put weight on it very hard
  4. guthriesmith
    guthriesmith
    I’m trying to figure out how 34 wishbones attached to an F1 axle. Guessing we aren’t really talking about much of a truck other than a cab on some other ch***is?
  5. Squablow
    Squablow
    Got any pictures? I can't even imagine what that looks like. My first guess is there is a severe issue with geometry that a rack and pinion is not going to solve. So many questions though.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Lets see some photo's of the suspension, that will help us. HRP
  7. Jmountainjr
    Jmountainjr
    ***uming the front end components are correctly ***embled, I would guess you are asking too much from a Vega box.
  8. seb fontana
    seb fontana
    from ct
    A 605 Sanginaw power box and GM Gen 11 pump will do wonders. Call Borgeson Steering
    49ratfink likes this.
  9. warbird1
    warbird1
    Way too much weight on the front end for a Vega gearbox!
  10. squirrel
    The lengths of the steering arm at the spindle, and the pitman arm at the steering box, also have something to do with it.
    Pictures will be necessary to help you.
  11. Kevin Ardinger
    Kevin Ardinger
    King pin Bearings on the bottom of the axle, not the top, correct?
  12. My Dad ran a 40 Chevy coupe, and a 54 Chevy pickup with a Corvair box in each car for years. The 54 Chevy truck was a daily driver for over 10 years with no problems. The 40 Chevy had the Corvair box installed in 1970, and still has that Corvair box in it to this day, so I don't think the Vega box is the problem.
  13. 49ratfink
    49ratfink
    I replied to an email from a lady at work once with "if you ask a question where the only possible replies are more questions you have failed at asking that question."
    I won't say that here though, apparently it is rude. :)
    clem, NoSurf, Just Gary and 5 others like this.
  14. gene-koning
    gene-koning
    Are you sure the tie rod center link is not dragging on the oil pan?
  15. squirrel
    If a human can't turn the steering wheel, would a motor be able to?
    49ratfink and guthriesmith like this.
  16. TCTND
    TCTND
    I have to agree that there is a problem here that should be corrected before power steering is added to the equation. After all the geometry and adjustments are sorted out you may still want to opt for PS as you have a hefty lump of Detroit wonder metal over that front end.
  17. Happydaze
    Happydaze
    What's the steering wheel diameter and how many turns lock to lock?
    Chris
    Lil 32 and 49ratfink like this.
  18. Jmountainjr
    Jmountainjr
    Hopefully the OP will post some pics and details. My questioning the Vega box suitability was based on the 460 - is it all cast iron or has it shed a bunch of weight with aluminum intake and heads. A fully dressed cast iron 460 is a scale tipper.
    warbird1 and 49ratfink like this.
  19. manyolcars
    manyolcars
    Sounds like a ratrod. I have been doing Ford hotrods since the 1960s----- what is a suicide front end?
  20. 19Eddy30
    19Eddy30
    from VA
    Spring behind front axle
    I Believe dirt track racers were doing in the 30s, gives front a Lower stance .
    I have Axle that was done in mid 60s in 0ne of my sheds.
    Yes Op build does sound like R-R,
    No pic's yet,
    As Mission previously wondering about the size of the steering wheel ?
    8 or 10 inch chain.
    seb fontana, Just Gary and 49ratfink like this.
  21. I doubt total weight is an issue. More likely to be ratio between steering items or maybe contact between them and something solid mounted in the Ch***is. Photos pal, photos!
    P.S. In the early 70's I had a 49 Ford Coupe with a 46-48 style front Axle setup and a 392 Hemi in it. Steering was not an issue. It can be done.
  22. RodStRace
    RodStRace
    6 posts, joined in 2009. Decent description, but no pictures.
    SEND PICS!
  23. alchemy
    alchemy
    Decent description? There are a hundred things that could be wrong with his truck. He told us very little about his truck. Pictures would probably result in a good resolution in ten minutes.
  24. oldolds
    oldolds
  25. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    So the king pins were not fitted??
  26. warbird1
    warbird1
    It may not be the issue creating the hard steering, but it's still more weight than a Vega box is recommended for.
  27. Curb weight and leverage pressure are 2 different things. Length of levers and angle of movement as well as pickup points play a large part of how well things move.
  28. blue 49
    blue 49
    from Iowa
    A GM Vega box is different than a chinesiam copy, too.
    Gary
  29. nochop
    nochop
    from norcal
    I would suspend the car on the axels and troubleshoot from there
