Need an FE wizard
Discussion in 'The Hokey Ass Message Board' started by segajeep, Jul 6, 2013.
  1. segajeep
    segajeep
    OK, so, have a 58 Edsel under the knife. It's got the e-400 361" FE engine. We 're monkeying around with the heads (needs a valve jaerb and headgaskets). An FE is an FE, right? Should I encounter any unforseen issues,390, 427 and 428 parts would fit ja? Like, for example, heads or valvetrain stuff?
  2. Hemi Joel
    Hemi Joel
    from Minnesota
    If you put big valve heads on that little motor, you need to check for valve to bore interference.
  3. 53 effie
    53 effie
    Well, I don't claim to be an FE wizard but to my knowledge most everything you mentioned interchanges. As long as you don't get into more exotic 427 stuff. You do have to watch valve sizes with smaller bores.
    The biggest thing I know is pre-63 uses a different cam with a "****on". The later ones had a plate on the block to hold the cam in place. So the timing or front covers are different because of that.
  4. 53 effie
    53 effie
    Your '58 may have adjustable rocker arms and even may solid lifters. I've not had an FE that early. I know in '58 Fords the early heads had fully machined combustion chambers instead of just cast and adjustable rocker arms. By '59, almost all were fully hydraulic with non- adjustable rocker arm. Only actual solid lifter motors had the adjustable rocker arm setup later on - some 390s, the 406 and 427s.
    If yours has the adjustable rocker arm stuff and you don't want to use it, don't throw it out. Other FE guys will want it.
  5. segajeep
    segajeep
    I'm not planning to swap the heads out. or ditch the original parts.It's just that no one lists part for an e-400, but if I can order seals and valves and whatever for a 360 or a 390, we can get the car rolling. The 361 is pretty stout for a small motor, 303 hp and 400 lbft
  6. If you edsel has the original mel engine with the fuel pump at the front near the distrubuter, there isnt any parts ( other than the spark plugs dist cap & rotor and oil filter )from a FE that will work. Post a picture of your engine. OldWolf
  7. mammyjammer
    mammyjammer
    from Area 51
    The correct answer for all Ford interchange questions is Maybe!
    But, for your valve job project, a quality FE gasket kit should have everything you need.
  8. Ole don
    Ole don
    You dont need to order valves for an E 400 engine. Measure them, overall diameter, stem diameter, and length, and order like valves from the book.
  9. segajeep
    segajeep
    The MEL was the 410 in the Citations and Corsairs, aka the E 475. The 361 aka E 400 is an FE. no?
  10. hoop98
    hoop98
    from Texas
    Supposedly the top of the block is angled 10 degrees
  11. mammyjammer
    mammyjammer
    from Area 51
    361 is a FE. Pull it apart and see what you need and let us know.Most of the parts should be easy enough to get....
  12. Jeff Walker
    Jeff Walker
    Yes it is definitely an FE engine. It will not have solid lifters or adjustable rocker arms. Head gaskets will be the same as other FE Fords. Try to find a head gasket set for a 64 or older FE engine to get the correct port size intake gaskets. The combustion chambers are fully machined. The intake valves will have a 30 degree seat as opposed to the more common 45 degree seat that later FE engines had.
  13. segajeep
    segajeep
    We are also considering headers if I can find them. These manifolds look awful for flow. I've been looking at stuff to fit a Fairlane with an FE, but there aren't many options. The rest of the engine has a slight performance build from the factory. I bet some headers and dual exhaust will help a lot.
  14. Dakota
    Dakota
    from Beulah, ND
    Ford powertrain sells headers for that Engine/Ch***is, they are 550$ a pair Uncoated.
  15. FrozenMerc
    FrozenMerc
    ^^^ Yep, Run with the FPA headers.
  16. sunbeam
    sunbeam
    Its pretty much the same as a 352 with the bore of a 390 or the 360 used in pickups.
