Technical Need brake advice.
Discussion in 'Traditional Hot Rods' started by LOWFLYE, Apr 10, 2024.
  1. LOWFLYE
    LOWFLYE
    Trying to help out my old buddy with the front brakes on his 1925 ford T bucket (has a 350 chev with automatic. Looking for and need to know what year Ford truck from the 1950s has self energizing brakes? thanks for sharing your knowledge.
    Cheers.
    Allan
  2. Rex_A_Lott
    Rex_A_Lott
    Maybe some pics would help. 56 F100 was a popular setup to run at one time. Good Luck
  3. Both the F1 (48-52) and F100 (53-56) had Bendix brakes, just remember to get the WHOLE setup (Hubs, backing plates and drums) for one Or the other setup. I do think the F100 setup is easier to get parts for though.
  4. CSPIDY
    CSPIDY
    Why use truck brakes, (curious)
    I have 40 ford car brakes on my 29 roadster and they will put you through the windshield
    as said use the whole system including the master cylinder
  5. Rex_A_Lott
    Rex_A_Lott
  6. ‘28 RPU
    ‘28 RPU
    Look up HAMB member “Rich” he know’s all that you need and may have the parts you need.
  7. Illustrious Hector
    Illustrious Hector
    What brakes , if any does it have now?
  8. RICH B
    RICH B
    If you are trying to ID the brakes on the car; here are a couple pictures of F series truck brakes to compare.
    They are 11" brakes and the only different parts between the F-1 and F-100 are hub and drum.
    leon bee and Speccie like this.
  9. manyolcars
    manyolcars
    Brake problems are so common that we need a separate sub-forum just for brakes
    Hillbilly Werewolf likes this.
  10. dsiddons
    dsiddons
    from Indiana
    I used these brakes on a few previous hot rods and by far worked lika champ. But keep in mind I purchased these completely rebuilt on ebay . A alternative is the Lincoln brakes that Thompson garage sells which I have now and also used in the past that are brand new . They are not cheap but nor is your life.
  11. 19Fordy
    19Fordy
    Bolling Bros. makes a great Lincoln Brake set up for old Fords.
  12. 19Fordy
    19Fordy
    Bolling Bros. also makes a great Lincoln Brake set up for early Fords. I have them on my 40 Ford. I still used the 1940 master cylinder.
    Contact Krylon on Fordbarn. He is the vendor I used and builds hot rods.
    Ask about his discount price.
