Need brake hose help.
Discussion in 'The Hokey Ass Message Board' started by Merc Ryan, Nov 6, 2011.
  1. Merc Ryan
    Merc Ryan
    from Phoenix
    I spent an hour and a half at Napa trying to get what I thought would be a simple hose. O'Reillys didn't have a clue either.
    I ordered a disc brake kit for the front of my 1959 Chevy Apache and it uses C10 calipers. It came with brake hoses that use have a female (inverted) 3/8's fitting and my truck has a female (inverted) 7/16ths. They are about 15" long.
    So the caliper side is correct with a banjo fitting, it's the 3/8" fitting that isn't right and I cannot find a car or truck that has a banjo on one side and inverted 7/16th on the other. I'm sure the part exists, I just can't seem to figure out what vehicle may have had it.
    Has anyone run into this problem and what brake hoses worked? What manufacturers used 7/16 more than 3/8? I know I can have some custom made, but it would be nice to be able to walk into an auto parts store and pick them up. I also know I can replum the hard lines and their junctions with 3/16ths or run some adapters. I don't want to run an adapter with the banjo block junction side or the line side if I can avoid it...
    Thanks!!!
  2. stimpy
    stimpy
    they sell adaptors in br*** for that they ussually are in the bins under the counter at napa s other than that your looking at remaking the pipe end of the line , or having a custom braided hose made
  3. EnglishBob
    EnglishBob
    Speedway I'm sure have them.
  4. 325w
    325w
    Look up your local hydrualic hose guy. They can usually make anything you need.
  5. Yeah, I'm thinking the Weatherhead box is gonna be your best freind on this one... Chances are the mfrs were all done with the 7/16 stuff before the banjos came on the scene.
  6. Merc Ryan
    Merc Ryan
    from Phoenix
    Thanks for all the replies. I ended up spending some time on Dormans website and found some good leads on what I was looking for. Seems like late model Cadillacs use 7/16-24 inverted flare fittings.
  7. meengrinch
    meengrinch
    from ipswich ma
    napa has a good chart in one of their old brake parts book.........lists all the hose end sizes on each end for easy recognition.......just did that for a 31 ford with weird hose ends
