Technical Need cam specs.
Discussion in 'Traditional Hot Rods' started by tfeverfred, Oct 10, 2013.
  1. tfeverfred
    tfeverfred
    Does anyone have the cam specs for a '64 with the 327 CI/300 HP Corvette?
  2. rat nasty
    rat nasty
    I bet that if you called one of the cam companies they would be able to help and duplicate that grind for you? with No prob? I've had great luck with cam motion for specific or custom grinds...Tadd
  3. henryj1951
    henryj1951
    from USA
  4. saltflats
    saltflats
    from Missouri
    Comp cam shows specs for a factory part # 3896929 witch thay show for a 65 to 68 275 /300 HP 327.
    Advertised duration of 319 in 320 ex 195 202 @.050 .390 in lift .410 ex lift lobe sep. 112
  5. tfeverfred
    tfeverfred
    Thanks, guys. I found it.
