Need Cheap way to convert brakes
Discussion in 'The Hokey Ass Message Board' started by weiserman, Aug 14, 2010.
  1. weiserman
    weiserman
    from Nebraska
    what is the best way to convert drum to disc brakes on a straight axle. Axle is from a econoline(61)
  2. Hellfish
    Hellfish
    I used this kit. Everything but the bracket is available off the shelf at your FLAPS. There are some junkyard conversions using AMC parts, I think. Do a search on the Econo yahoo groups.
    http://www.dddiscbrakes.com/kits.html
  3. Hellfish
    Hellfish
  4. wheels777
    wheels777
    from York, PA
    The one from tsm and DD bolt onto the inside of the spindle flange. The one in Carnut bolts to the outside. They both use the same caliper. Is the disc the same?
  5. Puddin Head
    Puddin Head
    from Mason, Oh
    Go to carnut.com and go to car tech. Has a 61-67 Econoline conversion. Contact Roger Mingus and he wll send you the info and template for the plate.
  6. Cheap is not to make the change. What are you trying to gain with the change?
    Charlie Stephens
  7. wheels777
    wheels777
    from York, PA
    125 trap speed and short shut downs.
  8. charlieb66
    charlieb66
    To see the words "cheap" and "brakes" used in the same sentence make me glad I don't live and drive in your hometown.
  9. propwash
    propwash
    from Las Vegas
    Ditto - my first thought when I read the ***le to your post.
