Projects Need different 700r4 dipstick.
Discussion in 'The Hokey Ass Message Board' started by Stevie Nash, Feb 6, 2015.
  1. Stevie Nash
    Stevie Nash
    Well, dropping a 401 nailhead in the 37 Nash. Using a 700r4 transmission for the overdrive. The transmission adapter moves the ****** back another 1 1/2" or so, so space is limited for the dipstick tube. A flexible dipstick would be great, but I only see the billet Lokar type style and I want to stay away from that.
    What are you guys using? Something black would be great. The Lokar "midnight" version is double the money, yikes!
  2. Roger O'Dell
    Roger O'Dell
    I used a pontiac one from their ls model
  3. 325w
    325w
    I measured mine. Cut it with a tubing cutter. Stuck the bends and pieces around till they fit. Used heat shrink tubing to hold the pieces together. Cut small hole thru the shrink at the joints and tack welded. Trial fit again. The n removed the heat shrink and Tig weled the joints. Then re measured and cut the dip stick to the correct length.
  4. Leakie
    Leakie
    Look for one out of a mid 90's Camaro or Firebird, they were set way back.
  5. jimpopper
    jimpopper
    Astro or Safari Minivan?
  6. mj40's
    mj40's
    Same combination in my 40 pickup. I figured with all of the bling no one would notice the flexible dip stick. mounted it as low as possible do the tube didn't show much. I plan on doing something with the handle so it looks older.
