Hot Rods Need experienced help please
Discussion in 'The Hokey Ass Message Board' started by V4F, Dec 1, 2011.
  1. V4F
    V4F
    from middle ca.
    ok , this is an old subject . i need help from someone who has put 1940 hyd brakes on a 30-31 model 'a' . i need to know the ends & outs please .............. steve
    kzsteve@yahoo.com
  2. 117harv
    117harv
    [​IMG] Rear brakes: Hub question. (Technical)
    sxdxmike
    Here is one good thread and there is another in the tech archive about modifing juice plates to work with 32-34 spindles. The model A spindles have the same four bolt pattern.
    Are you running an A banjo or later? Do you want/have to keep the A spindles?
  3. chrisntx
    chrisntx
    from Texas .
  4. V4F
    V4F
    from middle ca.
    i know 40 brakes are not the best , but i have them . so im going to try . i believe ted has a kit for them as well as the 'a's .
    yes 'a' banjo & yes i would like to keep it on 'a' spindles .......... thank you both .. steve
  5. 117harv
    117harv
    With all do respect, really:confused::cool:
    Yes, the 40 juice plates will work with the A spindles. In the rear as shown in the previous link they have to be rotated, new holes drilled so they clear the spring mount.
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've been running 40 brakes on my 27 for lots of years and had them on my 23 for a long time, they stop just fine. The key is to use new parts, set them up well, and keep them maintained. Only time they are not like discs is when they are real wet, but who wants discs on an early stye hot rod?
    Don
  7. oj
    oj
    Model 'a' banjo spring mount will get into hyd backing plates, cut out a pocket and they will just fit and the wheel cylinder can bolt up and clear everything - i don't have the shock mount on the top of my spring mount, that ball would screw the pooch for sure. Mine is a '28 model 'a'.
  8. V4F
    V4F
    from middle ca.
    i found one of the threads mentioned . excellent article . thank you all ................. steve
