Need flow characteristics for Weiand Drag Star or Edelbrock version...
Discussion in 'The Hokey Ass Message Board' started by scootermcrad, Nov 29, 2006.
  1. strombergs97
    strombergs97
    I believe Panic is right, if I understand him right..Log intakes will do better without the crossovers, equalizers. Separate logs..
    Do I understand you Panic..It would seem logical, less vacuum lose with separate logs.
    What about the X1 6x2 intake???
    Duane.
  2. if you want to make the most of a log intake, have a custom cam made do to a 4-7 swap so your firing order will be switched on those two cylinders. then a log manifold with the crossover tubes blocked will perform like a dual plane manifold, just kinda big with not nicely shaped runners.
