Technical Need Ford 3 Speed Toploader Education
Discussion in 'Traditional Hot Rods' started by texag09, Apr 24, 2018.
  1. texag09
    texag09
    There has been a ton of discussion on the early ford 3 and 4 speed toploaders, however I can not seem to find anyone converting a 4 wheel drive to a 2 wheel drive tailshaft. I have 2 free Ford Bronco 3 speed toploaders, is there a tailshaft housing that fits the existing tailshaft? If not what is the shortest tailshaft and housing combination available?
    Thanks in advance for all your help.
  2. squirrel
  3. sloppy jalopies
    sloppy jalopies
    broncos spring pads tilt the pinion upward, the pig may be offset to the right...[4 wheel drive]
  4. 51504bat
    51504bat
    Something like this from a local C/L add?
    00q0q_b31G8zZ1uwK_600x450.jpg early sixties Ford van top loader 3 speed transmission. Hard to find. tag letter code is h e f br. Has top mount tail shaft housing
    squirrel and Boneyard51 like this.
  5. 51504bat
    51504bat
    Another one with a different mount.
  6. Boneyard51
    Boneyard51
    Some of the early Econoline vans mounted their transmissions like that.
    **** , the way the wording was around the pic on my app.made me miss half your statement about the vans, but there is no threads on the Bronco transmission to hold the yoke on. Bones
  7. They made a dozen versions and there are thousands of those transmissions still around. Just buy one with the tail shaft you need. I have a couple dozen of those top loader three speeds in my hoard.
