Need headlight buckets that align with screws from the back, or just longer screws
Discussion in 'The Hokey Ass Message Board' started by grobb284, Jun 28, 2009.
  1. grobb284
    grobb284
    from Ohio
    Does anyone make a headlight bucket for a sealed beam where the two alignment adjustment screws are accessed from the back side?
    If that is not available, are longer adjustment screws available so I can make them accessible from the back side?
    I'm eliminating the headlight bezel and having just the headlight retaining ring pass through the fender opening for a smoother look.
  2. Bob K
    Bob K
    from Antigo Wi.
    Go to your local napa, they have an assortment of those screws in various lengths, that is exactly what I did on my 52, I cut holes in the back of the bucket,
    B:)B
  3. grobb284
    grobb284
    from Ohio
    Thanks for the response, Bob. That information about NAPA having the screws is helpful.
    Did you cut a square on the end of the screw to put a wrench on for adjustment, or something else?
  4. Bob K
    Bob K
    from Antigo Wi.
    Nope, I just slotted the end with a cut off wheel and use a screwdriver to adjust.
    B:)B
  5. grobb284
    grobb284
    from Ohio
    Excellent solution, thank you.
