Need help, 235 oiling problem
Discussion in 'The Hokey Ass Message Board' started by Tubby, Dec 7, 2006.
  1. Tubby
    Tubby
    My 235 is at the machine shop now for a rebuild. He primed the oiling system and it has 45 lbs of oil pressure but is not getting oil to the rocker ***embly and no internal oil p***age was found. Do we need to use an external oiling system or is there an oil p***age being overlooked?
  2. yorgatron
    yorgatron
    use the search function,this was covered in detail a couple years ago.
  3. 53sled
    53sled
    from KCMO
    no, the external filter system is independent and doesn't HAVE to be hooked up. inliners.org has a great write up on how to make it a full flow system, what better time than while at the machine shop!
  4. squirrel
    there were changes to the block in the late 50s, might help to know what year the block is, and also what type lifters it has. The later blocks don't work with earlier lifters.
    block casting date should be on the right rear of the block, look for a letter followed by two or three numbers, like B 14 8 which would translate as b = second month, february, 14th day of the month, and 8 is the last digit of the year, which would be 58.
  5. Tubby
    Tubby
    Squirrel, the block isn't local right now but I'll see if I can't get the machinist to find the numbers.
    Thaks, 53sled, Inliners does have a really nice write up.
  6. zman
    zman
    from Garner, NC
    One of the head bolts... I know the early 235's had one special headbolt...
