Projects Need help/advice on cleaning a brass radiator
Discussion in 'The Hokey Ass Message Board' started by Big Tony, Sep 12, 2011.
  1. Big Tony
    Big Tony
    Ok men, i have a br*** radiator in a bucket and need to know how to get it cleaned and buffed. I may have made a mistake by using Br***o b/c it made it worse.
    Thanks for the help in advance:D
  2. donnie gt
    donnie gt
    i use a product called autosol (napa) its a paste,seems to work o.k.!:)
  3. Big Tony
    Big Tony
    Thank you sir
  4. hotrod40coupe
    hotrod40coupe
    Flitz should work.
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    I started this one by using a fine sandpaper. The same grit you would use on block sanding a painted topcoat.
    Then clean it well and start the buffing with a machine. Start with a co**** and get a finer buff for each time.
    Finally you get to a point where it will begin to mirror. Fine dents make this difficult.
