can anyone help just bought a bbc 427 for my new project bought a 29 plymouth 4 dr can you put a turbo 350 behind it? and do you have to have special torque convertor? or will it bolt to the flywheel i have on the 427? thanks to everyone GARAGE RATS
A 350 turbo will bolt up to a GM th 400 flywheel. Converter size is up to the builder. Car weight and camshaft have to be considered.
Do not use a 400 flywheel, it has external weights and the 427 is ballanced internally, any small block or big block flywheel will work other than a 454 or 400. The 350 will bolt up .
Do yourself a favor and s**** the th350 and go with a th400. I dont know what your plans are for the car you are building but the th350 wont take the power output of even a mild big block, been there done that. I even went so far as to talk to a performance trans shop and was told that without several bucks a th350 wont survive. But the others are right any flexplate other than a 454 or 400 small block will fit. And if you are going to argue that the th350 has a lower 1st then the th400 you are correct but trust me a 427 wont give a hoot. Just my 2 cents worth.
The 350 can hold up to that 427 with no trouble....but what do I know I just build the damn things and have for 32 years. There's my Dollars worth.
bolts right up a turbo 350 built by a good trans guy will hold up fine. my trans guy has several of them in drag cars going tens he charges me 375 a ******. never had a problem
you guys are awesome i have alot better look on things now,thank you very much to all of you this will save me some bucks and thats what i do this is my first big block so wanna do it right tim
heh...you guys are talking about different 400s. You can use a TH400 flywheel, as long as it's not for the heavy duty 6 bolt converter. You don't want to use a flywheel for a 400 CI small block V8, as it's balanced wrong for a 350 engine. and if you do use a TH350, get onlychevrolets or other competent builder to put it together, with the knowlege that it's going behind a big block and needs to be strong.
good point...we just call em "wheels" gas engine older GM's have big wheels and small wheels...shop lingo for 153 and 168 tooth flexplates.
