***Need help ! carb info ***
Discussion in 'The Hokey Ass Message Board' started by -slim-, Sep 4, 2008.
  1. -slim-
    -slim-
    from Montreal
    I have a carter carburetor on my v6 1953 pontiac . What i need to know is what carb kit would i need for redo the carb ! I was told i need a 4 digit code !
    help !
    thanks !
  2. grapp
    grapp
  3. -slim-
    -slim-
    from Montreal
    I do have the tag ... I think ! would this work ? 20105 or s for the last diget ?
  4. Bruce Lancaster
    Bruce Lancaster
  5. -slim-
    -slim-
    from Montreal
    I look up the tag (2010-S) on the site you gave me and it says it's A Carter WCD 2010-S 2-barrel . ALSO SAYS ITS FOR <TABLE cellPadding=0 width=760 border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD vAlign=top width=360 itxtvisited="1"><TABLE style="BORDER-RIGHT: black 1px solid; BORDER-TOP: black 1px solid; BORDER-LEFT: black 1px solid; BORDER-BOTTOM: black 1px solid; BORDER-COLLAPSE: collapse" borderColor=black cellSpacing=0 rules=all border=1 itxtvisited="1"><TBODY itxtvisited="1"><TR cl***=***leLeft itxtvisited="1"><TD cl***=HeaderStyle style="WIDTH: 350px" colSpan=2 itxtvisited="1">Engines/Vehicles with this Fuel Feed</TD></TR><TR itxtvisited="1"><TD align=left colSpan=2 itxtvisited="1">3.9 Liter 6 Cylinders 115.00 HP
    1953 Plymouth</TD></TR><TR itxtvisited="1"><TD&NBSP;< itxtvisited="1" td></TR><TR itxtvisited="1"><TD align=left colSpan=2 itxtvisited="1">3.9 Liter 6 Cylinders 118.00 HP
    1953 Plymouth</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
  6. Bruce Lancaster
    Bruce Lancaster
    And the lines below those two, for '53 and 4 Pontiacs??
  7. Bruce Lancaster
    Bruce Lancaster
    The two is I would think a typo. Neither the Plymouth nor the two pontiacs got 2 barrels, as far as I know.
  8. JohnEvans
    JohnEvans
    from Phoenix AZ
    Ho Kay !! That is the correct # "2010 S " and it is a 2 barrel carb. I have in my litature collection a old Carter carb parts and service manual that covers up into the 60s. That carb is shown in all it's glory ! LOL !!
  9. squirrel
    it's even listed in the 35-53 Motors manual, 2010 S for a 53 Poncho
    but that's probably a straight 6, not a V6 :)
  10. Bruce Lancaster
    Bruce Lancaster
    Different kind of V-6...elderly Pontiac engines are known for sagging in the middle...
  11. -slim-
    -slim-
    from Montreal
    Yes straight 6, my mistake ! So now i know what one it is ,now to find a carb kit and the literature to rebuild it . Can anyone help me out with that ? P.S thanks for all the help so far guys !
  12. squirrel
    I can scan the motors manual pages, pm me. Most carb kits come with instructions and specs though.
  13. -slim-
    -slim-
    from Montreal
    Yet another problem ! While taking off the choke plate lever off of my carb which was already missing a screw ,the only screw holding it in place snaped off in the choke plate piston .So my question to you all is ,How do i take out the screws or where can i find another choke plate piston for my carb ??
  14. -slim-
    -slim-
    from Montreal
    Still looking for an answer ! Any help would be great !
  15. carbking
    carbking
    Choke plate and throttle plate screws were originally "staked" by the manufacturer to prevent them from backing out, and thus being ingested by the engine.
    To remove ANY choke or throttle plate screw, remove the staking from the back side prior to attempting to remove the screw. This may be done by using a Dremel with a diamond burr, or a fine flat file. If you (or some previous owner) has twisted off the any of the screws, give me a call, and I will talk you through several procedures that generally work.
    New screws are available in some of the top line carburetor rebuilding kits.
    The 2010s is indeed a two-barrel carburetor for use on 1953 and 1954 Pontiac 6 cylinder engines. This is an interesting carburetor in that some units have 2 idle mixture control screws, others have only 1. Not at the books right now, and do not remember if early production got 1 then revised to 2; or the other way around.
    Jon.
  16. -slim-
    -slim-
    from Montreal
    Jon,Thanks for the help !
  17. shpotty
    shpotty
    from New Jersey
  18. -slim-
    -slim-
    from Montreal
    If i'm unable to get the screws out, can anyone point me in the right direction to be able find a replacement chocke piston ,lever ,link and shaft for my Carter WCD 2010-S ?
    thanks for the help !
  19. carbking
    carbking
    All are available, but you are much better off salvaging yours.
    Jon.
  20. -slim-
    -slim-
    from Montreal
    How much would one cost with the screws ?
  21. -slim-
    -slim-
    from Montreal
    So it looks like i can't salvage mine and i want to get my car on the road as fast as possible . So can someone help me fine a new one ? i've called a few places and was not able to fine a choke shaft for my carb !
    Anyone please help !
  22. carbking
    carbking
    Both choke shafts and N.O.S. carburetors are readily available.
    Jon.
  23. -slim-
    -slim-
    from Montreal
    Now all i need are the screws !! help please ! Who has them ?
  24. carbking
    carbking
    Try your local hardware store. Should be 3 x 48 round-head machine screw.
    Jon.
